Experimenting with cerberus (last firmware) and micro sd card module (http://www.ghielectronics.com/catalog/product/359) I’ve got around a few rough edges. Mainly :
- never try to mount an already mounted card (causes boot lock up)
- when attempting to reinsert an sdcard after ejecting it first, the first access to the sdcard will eventually causes a lock up.
- you can workaround the previous issue, by checking if it is the second time the card has been mounted and rebooting the board instead.
Working code :
using System.Collections;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using Microsoft.SPOT.IO;
using System.IO;
namespace TestSD
public partial class Program
static private string root;
static private GT.Timer writeTimer;
static private GT.Timer BlinkTimer;
static private bool MountedOnce = false;
timer.Tick +=<tab><tab>
timer.Start();
BlinkTimer = new GT.Timer(1000);
BlinkTimer.Tick += new GT.Timer.TickEventHandler(BlinkTimer_Tick);
BlinkTimer.Start();
writeTimer = new GT.Timer(5000);
writeTimer.Tick += new GT.Timer.TickEventHandler(writeTimer_Tick);
sdCard.SDCardMounted += new SDCard.SDCardMountedEventHandler(sdCard_SDCardMounted);
sdCard.SDCardUnmounted += new SDCard.SDCardUnmountedEventHandler(sdCard_SDCardUnmounted);
button.ButtonPressed += new Button.ButtonEventHandler(button_ButtonPressed);
static private bool toggleled = true;
void BlinkTimer_Tick(GT.Timer timer)
if (sdCard.IsCardMounted)
Mainboard.SetDebugLED(toggleled);
toggleled = !toggleled;
Mainboard.SetDebugLED(false);
void button_ButtonPressed(Button sender, Button.ButtonState state)
sdCard.UnmountSDCard();
void sdCard_SDCardUnmounted(SDCard sender)
writeTimer.Stop();
void sdCard_SDCardMounted(SDCard sender, GT.StorageDevice SDCard)
if (MountedOnce)
Thread.Sleep(100);
Microsoft.SPOT.Hardware.PowerState.RebootDevice(true);
root = SDCard.RootDirectory;
writeTimer.Start();
MountedOnce = true;
void writeTimer_Tick(GT.Timer timer)
string fileName = Path.Combine(root, "file.txt");
Stream stream;
if (File.Exists(fileName))
stream = File.OpenWrite(fileName);
stream.Position = stream.Length;
stream = File.Create(fileName);
using (var writer = new StreamWriter(stream))
Debug.Print("Writing ok");
writer.WriteLine(Guid.NewGuid().ToString());
stream.Dispose();
else timer.Stop();
Is anybody experiencing the same thing, did I forgot something obvious and/or arcane ?
Regards
