Cerberus and CAN DW Module
Hello everyone,
I am a student in computer science in France. In the context of a robotic project, I use the FEZ Cerberus card. I contact you because I have a problem with the CAN DW Module.
I made several tests with the Spider card everything goes well. But when I want to test with the card Cerberus, the error message is:
[quote]The Module Could not be added:
  • A required library could not be found.[/quote]
Now I have to reinstall several times Library provided by the site following the procedure …
I use as Microsoft Visual Studio 2010.
Thank you in advance.
What is the date of the SDKs you have installed?
What version of the Micro Framework are you targeting? The Cerberus only supports MF 4.2.
The support for CAN is partial on Cerberus. Do not add the module in the designer and then you can develop the drivers directly.
This should help get you started http://www.tinyclr.com/codeshare/entry/552
ok thanks i will try
