I have exact the same situation :
Updated the 4.2 to the latest version today aftes de-installing all 4.2 software (left 4.1 As Is)
Connected my spider
created a new project : Gadgeteer 4.2 (in c#) (and also tried the same in VB)
just a button and simple command (or even JUST the SPIDER with only the standard Program.cs )
BUILD \ Run gives the same outout as mentioned by mhectorgato.
when i create a new project. with only the Spider Mainboard, The program.cs starts off by not recognising the
using Gadgeteer.Networking
; line
remove that for nowā¦
now i run and i get the same errors that all kinds of references dont match (see mhectorgato.)
Now i checked my Gadgeteer reference => 2.41.0.0 but when i Double click it I see that it refers to the location
C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Mainboards\FEZSpider\NETMF 4.1\GHIElectronics.Gadgeteer.FEZSpider.dll
I remove it and replace it with the dll in the 4.2 directory looks good when i check the location nowā¦
Doing the same for the GHIElectronics.Gadgeteer.FEZSpider dll. (also shows to have the 4.1 directory)
I replace it by the one found in C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Mainboards\FEZSpider\NETMF 4.2\GHIElectronics.Gadgeteer.FEZSpider.dll (double checked this), but when i check the replaced reference, it still shows the 4.1 directory as source ???
I shall remove everything from the PC and install one more time⦠any ideas >>> ?
thanks
Bert
I checked, and indeed all the GHIElectronics.xxx drives reference the path
C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\RS232\NETMF 4.1\GTM.GHIElectronics.xxxxx.dll
@ Architect - One pc is fine but on my main laptop it references the wrong dll.
Uninstall of the previous sdkās and install of the latest.
Everytime i create a 4.2 Gadgeteer project it references the 4.1 Gadgeteer.dll
I will have a further dig tomorrow as it is a tad irritating.
I had the exact same issue. gadgeteer.dll was the 2.41 version within a 4.2 build. Removing and repointing to the correct file fix it (2.42 version).
I remember I installed step 4, the optional one that installed 4.1. Sooo, I uninstalled everything and did not do step 4. Works fine now.
Iām only guessing that the step 4 did the damage. The machine I installed it on never had 4.1 installed. I guess I really donāt need it. Not worth the time to make the point.
Speaking of time. Is it just my machine but does it take an inordinate amount of time to load the toolbox content?
@ jwschull - do you by chance have telerik tools installed? If you search on the guid that it stalls on there is a solution on the slow toolbox issue.
I had the same issue which was caused by telerik install.
