I recently bought a Cerb40 II. When I received it, I updated my desktop to the latest Gadgeteer/NETMF 2014 R1 SDK firmware. Then I updated tinybooter, tinyCLR and then the NETMF firmware on the Cerb40 II.
But now when I attempt to deploy a program to the Cerb40 II from VS2010 Express I only get “check you hardware” errors. I have not been able to deploy once. All my other Gadgeteer/SOM stuff works after the update.
My setup is Windows 7 64-bit, VS2010 Express and I am connected to the Cerb40 thru a powered USB hub. I’ve tried connecting directly to my CPU’s usb port with same results
I have searched the forum for the past few days and could only find some similar posts that went unsolved/unanswered.
When my Cerb gives me hardware error in VS.Net, I use to open up Fez Deploy and hit Erase application. Restart the device and head back to VS… Usually fix the problem at my place.
In device manager I see GHI NETMF Debug Interface.
All my other mainboards work.
I just tried a new VS2010 project and still have the same results. You see the name of the Cerb in the project properties but when you go to deploy its an immediate "check hardware"
error.
I have not been able to successfully deploy once so I am assuming there is no program running on the Cerb.
I tried MFDeploy but nothing shows up under the USB dropdown menu.
Still no luck getting my brand new Cerb40-II to work properly.
I’ve done some experimenting and noticed something. Starting from new VS2010 console application with nothing in it except a debug.print statement I can get VS2010 to deploy and run and application on my Cerb that prints to the debug window.
But if I add a Microsoft.Spot.Hardware reference and try to deploy it never works. Either VS2010 freezes in mid deployment or I get a check your hardware error.
If I then remove the Microsoft.Spot.Hardware reference and deploy, VS2010 freezes again in mid deployment. If I try to deploy a second time with the Microsoft.Spot.Hardware reference removed the deploy is successful.
@ charlieHustle - Are you using a USB 3 port or HUB by chance? If not, during deployment, are any of the other applications running in the background (MFDeploy, FEZConfig or DFU)? We have seen this kind of behavior in both of these cases.
