Cerb40 Hello World
Following this link:
http://www.ghielectronics.com/docs/21/first-netmf-project
When this project is built, and run on the Cerb40, the output screen shows this:
Looking for a device on transport ‘USB’
Starting device deployment…
Iteration 0
Opening port \?\USB#VID_1B9F&PID_0102#6&3532c170&0&1#{09343630-a794-10ef-334f-82ea332c49f3}\Operations
Attaching debugger engine…
… debugger engine attached!
Querying device assemblies…
Waiting for device to initialize…
(it never stops saying this forever…)
It repeats that until the device is unplugged.
I tried again using one of the code samples posted by a user under FEZ_Cerb40_Digital_Input_1 and saw the same thing.
The MFDeploy.exe shows this after a Ping
Pinging… TinyBooter
Since this is the very first project to try, I would like to get it working.
Thanks.
How are you powering your board? Try no hub or powered hub.
If MFDeploy ping returns “tinybooter” then you have one of two things happening. First, you have entered tinybooter mode through the loader buttons. Second, you do NOT have a microframework firmware deployed. So first up check LODR isn’t connected to anything, and then apply the firmware correctly. If you can’t get MFDeploy to return “TinyCLR” then there’s no point trying to deploy code, so I’m pretty sure once we get past firmware you should be fine !
Oh yes i missed that. Please see http://www.ghielectronics.com/docs/165/netmf-and-gadgeteer-troubleshooting
