Cerb40 cannot deploy
I have firmware updated a Cerb40 a couple of times now - this goes fine.
But, I cannot deploy, even with out adding code to the standard FEZCeberus project - It is preparing for ever, no reboot.
I saw an old post with the same problem, but no solution.
Hi Niels,
I had the same problem on FEZ Cerbuino Bee the first time I updated the firmware.
It turns out that I didn´t erase the flash memory before loading the Tiny Booter. So, if you are having the same problem I had, Step 3 of the update firmware should be the solution:
Do not tell this to any one!
I was just so focused on the new STDFU Tester that I forgot to use MS Deploy, also.
Without firmware - no fun!
@ Niels Soeren - tehehe - don’t worry, i have done the same :smiley:
Indeed, it’s a phase we all need to go through :slight_smile:
@ Gus - is a CerberusUpdater in the works or is this always going to require two steps? I haven’t heard any mention of it.
I do not know.
