Hello,
there are already some other threads dealing with this topic, but I could not find a proper solution that helped me out.
I installed “CDC_Driver.inf” and it seemed that this was done correctly. When starting my application a connection was established but when sending data nothing could be received.
Afterwards it tried to install “GHI_NETMF_Interface.inf”, but it was refused by Win7.
I replaced all entries “vid_1B9F&Pid_F003&MI_00” by “vid_1B9F&Pid_F003&Rev_0100”. Now it was possible to install this driver. But even with this driver the communication did not work.
Is the CDC_Driver.inf the basic driver without debugging interface and the GHI_NETMF_Interface the same but with with debugging? Or are the totally different?
Is there anything else that I should keep in mind?
The application works under WinXP, so it seems the be a driver problem.
Best regards,
Sören
