CDC Serial question
When I use from example, it read only one char at each send from client application with :
serial.Write("Test");
                var len = usbclient.ByteToRead;
                if (len > 0)
                    var dataR = new byte[len];
                    var dataW = new byte[len];
                    int read = usbclient.Read(dataR);
                    for (var i = 0; i < read; i++)
                        dataW[i] = (byte)(dataR[i] + 1);
                    usbclient.Write(dataW);
                Thread.Sleep(100);
You mean
Write(“T”),
Write(“e”),
Write(“s”),
Write(“t”),
will get all “Test”
But Write(“Test”) then Cdc got only “T” ?
What do you have on the PC side? Teraterm?
That’s it ! When sending a string or a buffer with multi byte, only first char or byte is received. If I do a write foreach byte it is working.
Just a winform with serialport.
Check how many bytes you got. Does it say 1, 4 or 8?
Also there is an even with count.
I will check by self later anyway.
In TinyClr app, only one.
In Winform app, it sends 4 bytes, and receives 4 bytes (if I do a write for each byte to sending them).
Fixed. Thanks for pointing it out.
@Bauland Please test in preview 3 and let us know if you are happy.
It’s working !!! Thanks to fix it.
