So… I have done a logon system that connects to a service via Network. It works great until the service is either shutdown or networkcable is disconnected.
i know im getting SocketExceptions. However i cant seem to catch them in anyway.
#### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (24) ####
#### Message:
#### Microsoft.SPOT.Net.SocketNative::send [IP: 0000] ####
#### System.Net.Sockets.Socket::Send [IP: 0018] ####
#### System.Net.Sockets.NetworkStream::Write [IP: 0051] ####
#### System.Net.InputNetworkStreamWrapper::Write [IP: 000a] ####
#### System.Net.HttpWebRequest::SubmitRequest [IP: 007d] ####
#### System.Net.HttpWebRequest::GetResponse [IP: 000c] ####
#### Gadgeteer.Networking.HttpRequest::HandleRequestSync [IP: 01a8] ####
#### SocketException ErrorCode = 10054
A first chance exception of type 'System.Net.Sockets.SocketException' occurred in Microsoft.SPOT.Net.dll
#### Exception System.Net.WebException - 0x00000000 (24) ####
#### Message:
#### System.Net.HttpWebRequest::GetResponse [IP: 00c8] ####
A first chance exception of type 'System.Net.WebException' occurred in System.Http.dll
Is there anyway to catch these exceptions or in anyway.
Trying to display a error message once the connection is unavailable.
Any tips would be nice and extreamly helpful.
@ omborddata - Can you post some code that shows how you use networking? You should be able to catch them around send/receive calls.
if (c != null)
try
HttpRequest httpReq = WebClient.GetFromWeb("http://" + Variables.ServiceSett.ServiceHostnameIP + ":" + Variables.ServiceSett.PortNumber + "/ODCardReaderService" + "/signonoff?ID=" + c.Card + "&IP=" + Variables.DeviceCurrentIP + "&DevID=" + Variables.ServiceSett.DeviceName );
HttpRequest.ResponseHandler resp = new HttpRequest.ResponseHandler(Program_ResponseReceived);
httpReq.ResponseReceived += resp;
catch (Exception ex)
//Call ShowErrorWindow("SERVERERROR")
string s = "";
Debug.Print(ex.Message);
finally{
c = null;
Thread.Sleep(50);
This is the code where the exception is happening. The code works fine while service and cable is connected.
@ omborddata - It looks like Gadgeteer might be doing things internally on a different thread that you cannot catch. You can always take a look at its source to dig deeper: http://gadgeteer.codeplex.com/
@ andre.m
I was expecting this to happen, i want to catch the exception to display a error message and to reset to another screen on the device. As it is right now when this exception is thrown i stays on a screen and stays there untill either you reconnect the cable and start the service, but i want the catch the exception for cosmetic reasons.
Yea checking for network access is easy i posted the wrong socketException. The part where i needed to catch that is when the service is down, i managed to fix it with a while loop, but it didnt handle fast requests. And begin to live its own life when you try to do a couple of card swipes in a row in fast succession.
But thanks for everything ill look in to it and post if i find anything.
