@ RoSchmi - now, I changed your driver
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using GTI = Gadgeteer.Interfaces;
using Gadgeteer.Modules.RoSchmi;
using Microsoft.SPOT.IO;
using Microsoft.SPOT.Input;
namespace Bluetooth_Pairing_Test
public partial class Program
//********** Presets: Parameter to be changed by users ***************************
const string MyDeviceName = "G120HDR"; // Device Name
const string MyPinCode = "0000"; // Pin Code
const int MySocketNumber = 4; // The SocketNumber of the mainboard to which the BT-Module is connected
const long BT_Device_Baudrate = 38400; // Baudrate
// possible baudrates 9600, 19200, 38400, 57600, 115200, 230400, 460800
const bool ReadMode_ByteArray = true; // false: data are received as strings -Event: bluetooth_DataReceived
// true: data are received as byte array-Event: bluetooth_DataByteArrayReceived
const bool FastReadMode = true; // true: switch to transmit without parsing
// false: data are always parsed for BT-module messages
const int MyEventDelay = 20; // Choose higher value if data received events queue up ( 20 = standard)
// has no effect in ReadMode_ByteArray Mode in combination with FastReadMode
const int SendInterval = 1000; // In this time interval we send a message to the BT-Module
//**************** End Parameter to be changed by user ***************************
static private Bluetooth bluetooth;
static private Bluetooth.Client client;
static int MessageCounter = 0; // Counter to count the sent messages
static long BytesTransferred = 0;
static long LastBytesTransferred = 0;
static long baudrate = 0;
static long events = 0;
static long lastevents = 0;
static long eventspersec = 0;
static long showEvent = 0;
byte[] datadrain = new byte[2000]; // Dummy, here we can put the received data
// timerSendData is used to fire in interval to send data to the BT-Module
GT.Timer timerSendData;
// timer, used to calculate statistics every 2 seconds (not needed in applications)
GT.Timer CalculateBaudrate;
// timerEnterPairing is used to enter pairing mode automatically
GT.Timer timerEnterPairing;
string dataLine1 = null; // used to process incoming data in eventhandler: bluetooth_DataReceived (as String)
string dataLine2 = null; // used to process incoming data in eventhandler: bluetooth_DataByteArrayReceived (as Byte Array)
byte[] ReceivedBytes; // used to process incoming data in eventhandler: bluetooth_DataReceived (as String)
SerialBuffer mySerialBuffer; // used to connect incoming data chunks and split after LineFeed (0x0A)
#region ProgramStarted()
SetupWindow();
// Do one-time tasks here
// Set up an optional RS232 Module with baudrate 38400 to send data to another PC
// you can leave it away if you have no RS232 module
try
rs232.Initialize(38400, GTI.Serial.SerialParity.None, GTI.Serial.SerialStopBits.One, 8, GTI.Serial.HardwareFlowControl.NotRequired);
catch (Exception e)
Debug.Print(e.ToString());
if (!rs232.serialPort.IsOpen)
rs232.serialPort.Open();
// Event handler for button to enter pairing mode
//button.ButtonPressed += new Button.ButtonEventHandler(button_ButtonPressed);
// Set a timer to enter pairing mode after 3 seconds
timerEnterPairing = new GT.Timer(3000,GT.Timer.BehaviorType.RunOnce);
timerEnterPairing.Tick +=new GT.Timer.TickEventHandler(timerEnterPairing_Tick);
// Set a timer to send data to the BT-Module in intervals
timerSendData = new GT.Timer(SendInterval);
timerSendData.Tick += new GT.Timer.TickEventHandler(timerSendData_Tick);
timerSendData.Stop();
CalculateBaudrate = new GT.Timer(2000, GT.Timer.BehaviorType.RunContinuously);
CalculateBaudrate.Tick += new GT.Timer.TickEventHandler(CalculateBaudrate_Tick);
CalculateBaudrate.Start();
// define a bluetooth module running on socket: "MySocketNumber", baudrate: "BT_Device_Baudrate"
Debug.Print("Program Message: Initialize Bluetooth module on Port " + MySocketNumber.ToString()
+ " Baudrate: " + BT_Device_Baudrate.ToString());
bluetooth = new Bluetooth(MySocketNumber, BT_Device_Baudrate);
bluetooth.EventDelay = MyEventDelay; // Choose higher value in "Presets" if data received events queue up ( 20 = standard)
// Set the Mode to receive data as Strings or as Byte Array depending on the settings in "Presets"
bluetooth.SetReadMode_ByteArray(ReadMode_ByteArray);
// Set up eventhandler for state changes
bluetooth.BluetoothStateChanged += new Bluetooth.BluetoothStateChangedHandler(bluetooth_BluetoothStateChanged);
// Set up eventhandler to receive data from the Bluetooth module as Strings or as Byte Arrays (only one is needed)
bluetooth.DataReceived += new Bluetooth.DataReceivedHandler(bluetooth_DataReceived);
bluetooth.DataByteArrayReceived += new Bluetooth.DataByteArrayReceivedHandler(bluetooth_DataByteArrayReceived);
Debug.Print("Program Message: Set Bluetooth module to Client Mode" + "\r\n");
client = bluetooth.ClientMode;
Thread.Sleep(200);
Debug.Print("Program Message: Set Device Name: " + MyDeviceName + "\r\n");
bluetooth.SetDeviceName(MyDeviceName);
Thread.Sleep(2000); // time was not tested
Debug.Print("Program Message: Set Device Pincode" + "\r\n");
bluetooth.SetPinCode(MyPinCode);
Debug.Print("Program Message: Set BT-Device to: Disable Auto-connect " + "\r\n");
bluetooth.DisableAutoConnect();
Thread.Sleep(200);
Debug.Print("Program Message: Set BT-Device to: Enable Auto-connect " + "\r\n");
bluetooth.PermitAutoConnect();
Thread.Sleep(200); // time was not tested
Debug.Print("Program Message: Set BT-Device to: PermitBeConnected" + "\r\n");
bluetooth.PermitBeConnected();
bluetooth.serialPort.DiscardInBuffer();
bluetooth.serialPort.DiscardOutBuffer();
Thread.Sleep(200);
mySerialBuffer = new SerialBuffer(256);
timerSendData.Start();
timerEnterPairing.Start();
#endregion
#region CalculateBaudrate_Tick (this is needed only to calaculate statistics)
void CalculateBaudrate_Tick(GT.Timer timer)
baudrate = ((BytesTransferred - LastBytesTransferred) / 2) * 10;
LastBytesTransferred = BytesTransferred;
eventspersec = (events - lastevents) / 2;
lastevents = events;
#endregion
#region timerSendData_Tick Sends a message over the Bluetooth Connection
void timerSendData_Tick(GT.Timer timer)
//Debug.Print("Program Message: ____________________________timerSendData ticked");
// check to see that the bluetooth module is connected, and if so send a message over the connection
if (bluetooth.IsConnected)
//Debug.Print("Program Message: BT is connected, so I send the message: " + "Hello from TinyClr, Message No.: " + MessageCounter.ToString());
client.Send("Hello from TinyClr, Message No.: " + MessageCounter.ToString() + "\r\n");
MessageCounter++;
Debug.Print("Program message: BT is not connected, cannot send message");
#endregion
#region button_ButtonPressed Enter Pairing Mode
private Bitmap normalButton;
private Bitmap pressedButton;
private Image imgButton;
private Text txtMessage;
private void SetupWindow()
Font baseFont = Resources.GetFont(Resources.FontResources.NinaB);
normalButton = Resources.GetBitmap(Resources.BitmapResources.NormalButton);
pressedButton = Resources.GetBitmap(Resources.BitmapResources.PressedButton);
Window window = display_TE35.WPFWindow;
Canvas canvas = new Canvas();
window.Child = canvas;
imgButton = new Image(normalButton);
imgButton.TouchDown += new TouchEventHandler(imgButton_TouchDown);
imgButton.TouchUp += new TouchEventHandler(imgButton_TouchUp);
canvas.Children.Add(imgButton);
Canvas.SetTop(imgButton, 50);
Canvas.SetLeft(imgButton, 90);
txtMessage = new Text(baseFont, "Button is NOT PRESSED");
canvas.Children.Add(txtMessage);
Canvas.SetTop(txtMessage, 200);
Canvas.SetLeft(txtMessage, 90);
private void imgButton_TouchUp(object sender, TouchEventArgs e)
imgButton.Bitmap = normalButton;
txtMessage.TextContent = "Button is NOT PRESSED";
private void imgButton_TouchDown(object sender, TouchEventArgs e)
imgButton.Bitmap = pressedButton;
txtMessage.TextContent = "Button is PRESSED";
// void button_ButtonPressed(Button sender, Button.ButtonState state)
// check to see that the bluetooth module is connected, and if so do nothing
Debug.Print("Program Message: You pressed the button but BT was connected, so not activating pairing mode");
// otherwise, just go into first-time pairing mode.
Debug.Print("Program Message: You pressed the button and BT was not connected, so I go to pairing mode");
client.EnterPairingMode();
#endregion
#region timerEnterPairing_Tick Enter Pairing Mode
void timerEnterPairing_Tick(GT.Timer timer)
if (!bluetooth.IsConnected)
Debug.Print("Enter pairing mode by timer event");
#endregion
// You have the choice to receive the data as strings or as ByteArrays. You need only one
#region Eventhandler -- Receive data as Strings
// Select this output mode with the bluetooth.SetReadMode_ByteArray(false) command
private void bluetooth_DataReceived(Bluetooth sender, string data)
ReceivedBytes = System.Text.UTF8Encoding.UTF8.GetBytes(data);
mySerialBuffer.LoadSerial(ReceivedBytes, 0, ReceivedBytes.Length);
// To see the chunks of data we can activate this Debug.Print
//Debug.Print("\r\n Program Message: Received chunk of data (String Mode). Byte-Count: " + data.Length.ToString() + " Data: " + HexEncoding.ToString(ReceivedBytes, 0, ReceivedBytes.Length) + "\r\n" + data + "\r\n");
while ((dataLine1 = mySerialBuffer.ReadLine()) != null)
Debug.Print("Line Received: " + dataLine1);
// If we have a RS232 module connected we can send the received data to another PC
//rs232.serialPort.Write(dataLine1 + "\r\n");
// parse the data sentence here if needed
#endregion
#region Eventhandler -- Receive data as Byte Arrays
// Select this output mode with the bluetooth.SetReadMode_ByteArray(true) command
void bluetooth_DataByteArrayReceived(Bluetooth sender, byte[] data, int startIndex, int ByteCount)
BytesTransferred += ByteCount;
events++;
Array.Copy(data, startIndex, datadrain, 0, ByteCount); // Dummy for the time it takes to get the data (they are not valid for a long time)
// if we want to see from time to time a short segment of the data, we send them over rs232
// we cannot see longer segments as we get buffer overflows
if ((events > showEvent + 50) && (events < showEvent + 53)) // arbitrary values to show some transmitted data
mySerialBuffer.LoadSerial(data, startIndex, ByteCount);
showEvent = events;
if (ByteCount < 100) // for short messages we send it over rs232
else // for high speed data we only send the statistics
rs232.serialPort.Write("Bytes Transferred: " + BytesTransferred.ToString() + " Bytes per event: " + ByteCount.ToString() + " Estimated Baudrate: " + baudrate.ToString() + " Received Events per sec: " + eventspersec.ToString() + "\r\n");
while ((dataLine2 = mySerialBuffer.ReadLine()) != null)
rs232.serialPort.Write(dataLine2 + "\r\n");
#endregion
#region Eventhandler signalizing that the BTSTATE of the Bluetooth module has changed
void bluetooth_BluetoothStateChanged(Bluetooth sender, Bluetooth.BluetoothState btState)
// here the bluetooth module's state has changed. First, just debug print the value so we know what is happening
Debug.Print("New state:" + btState.ToString());
// If the state is now "connected", we can do stuff over the link.
if (btState == Bluetooth.BluetoothState.Connected)
Debug.Print("\r\n Program Message: BT-Connection established, BTSTATE: " + btState.ToString() + "\r\n");
bluetooth.SetFastReadMode(FastReadMode); // Set fastReadMode, depending on the flag in presets
Thread.Sleep(1000); // do this to wait for BT module to connect;
client.Send("\r\nConnected to Fez\r\n");
// if the state is now "disconnected", you might need to stop other processes but for this example we'll just confirm that in the debug output window
if (btState != Bluetooth.BluetoothState.Connected)
// Debug.Print("\r\n" + "Program Message: Bluetooth disconnected, BTSTATE: " + btState.ToString() + "\r\n");
#endregion
the output shows that
Found debugger!
Create TS.
Loading start at a0e857d8, end a0e9cf34
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1) Assembly: Microsoft.SPOT.Security.PKCS11 (4.2.0.0)
Assembly: System.Security (4.2.0.0) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: Microsoft.SPOT.IO (4.2.0.0) Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Graphics (4.2.0.0) Attaching deployed file.
Assembly: System.Http (4.2.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.2.0.0) Attaching deployed file.
Assembly: GHI.Premium.Hardware (4.2.11.0) Attaching deployed file.
Assembly: System (4.2.0.0) Attaching deployed file.
Assembly: Gadgeteer.Serial (2.42.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Touch (4.2.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.TinyCore (4.2.0.0) Attaching deployed file.
Assembly: GHI.Premium.System (4.2.11.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.2.0.0) Attaching deployed file.
Assembly: Bluetooth_Pairing_Test (1.0.0.0) Attaching deployed file.
Assembly: System.IO (4.2.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Display_TE35 (4.2.100.0) Attaching deployed file.
Assembly: System.Net.Security (4.2.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0) Attaching deployed file.
Assembly: MCormier.Gadgeteer.G120HDR (1.0.0.1) Resolving.
GC: 1msec 537864 bytes used, 6801804 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 6801804 bytes
Type 17 (ASSEMBLY ): 34284 bytes
Type 1E (BINARY_BLOB_HEAD ): 503484 bytes
GC: performing heap compactionâŚ
Ready.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Security.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Graphics.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.TinyCore.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.IO.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.2\le\Gadgeteer.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.Security.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Net.Security.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Http.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âD:\thesis\test\G120HDR\G120HDR\G120HDR_42\bin\Debug\le..\GHI.Premium.System.dllâ
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âD:\thesis\test\G120HDR\G120HDR\G120HDR_42\bin\Debug\le..\GHI.Premium.Hardware.dllâ
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.2\le\Gadgeteer.Serial.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Touch.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âC:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Display_TE35\NETMF 4.2\le\GTM.GHIElectronics.Display_TE35.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âD:\thesis\test\G120HDR\G120HDR\G120HDR_42\bin\Debug\le\MCormier.Gadgeteer.G120HDR.dllâ, Symbols loaded.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Managed): Loaded âD:\thesis\test\Bluetooth_Pairing_Test\Bluetooth_Pairing_Test\bin\Debug\le\Bluetooth_Pairing_Test.exeâ, Symbols loaded.
The thread ââ (0x2) has exited with code 0 (0x0).
Warning: socket 5 is not compliant with Gadgeteer : Cpu pin 3 must be specified for socket of type D
Warning: socket 5 is not compliant with Gadgeteer : Cpu pin 6 must be specified for socket of type D
Warning: socket 5 is not compliant with Gadgeteer : Cpu pin 7 must be specified for socket of type D
Using mainboard GHI Electronics G120HDR version 2.0
Program Started
Program Started
Program Message: Initialize Bluetooth module on Port 4 Baudrate: 38400
Message from Class Bluetooth 1: Baudrate set to 38400
Message from Class Bluetooth: Try to set BT-Module baudrate to: 38400
Message from Class Bluetooth: Could not connect to BT-Module with baudrate 38400 in 501.69920000000002 msec
Message from Class Bluetooth 1: Baudrate set to 9600
Message from Class Bluetooth: Try to set BT-Module baudrate to: 9600
Message from Class Bluetooth: Could not connect to BT-Module with baudrate 9600 in 501.8032 msec
Message from Class Bluetooth 1: Baudrate set to 19200
Message from Class Bluetooth: Try to set BT-Module baudrate to: 19200
Message from Class Bluetooth: Could not connect to BT-Module with baudrate 19200 in 501.76160000000004 msec
Message from Class Bluetooth: Could not connect to BT-Module with baudrate 38400 in 501.93920000000003 msec
Message from Class Bluetooth 1: Baudrate set to 57600
Message from Class Bluetooth: Try to set BT-Module baudrate to: 57600
WARN: Total initialization time exceeds 10 seconds.
: ProgramStarted is blocking execution, which means events and timers will not run properly.
: Make sure not to use blocking code such as while(true) - use a GT.Timer instead.
Message from Class Bluetooth: Could not connect to BT-Module with baudrate 57600 in 502.12480000000005 msec
Message from Class Bluetooth 1: Baudrate set to 115200
Message from Class Bluetooth: Try to set BT-Module baudrate to: 115200
Message from Class Bluetooth: Could not connect to BT-Module with baudrate 115200 in 502.1216 msec
Message from Class Bluetooth 1: Baudrate set to 230400
Message from Class Bluetooth: Try to set BT-Module baudrate to: 230400
Message from Class Bluetooth: Could not connect to BT-Module with baudrate 230400 in 501.71680000000003 msec
Message from Class Bluetooth 1: Baudrate set to 460800
Message from Class Bluetooth: Try to set BT-Module baudrate to: 460800
Message from Class Bluetooth: Could not connect to BT-Module with baudrate 460800 in 502.19200000000001 msec
Message from Class Bluetooth: Could not connect to BT-Module with baudrate 38400 in 501.68800000000005 msec
Message from Class Bluetooth: Could not connect to BT-Module with baudrate 9600 in 501.67040000000003 msec
Message from Class Bluetooth: Could not connect to BT-Module with baudrate 19200 in 501.48320000000001 msec
WARN: Total initialization time exceeds 20 seconds.
Message from Class Bluetooth: Could not connect to BT-Module with baudrate 38400 in 501.952 msec
Message from Class Bluetooth: Could not connect to BT-Module with baudrate 57600 in 501.66560000000004 msec
Message from Class Bluetooth: Could not connect to BT-Module with baudrate 115200 in 502.43520000000001 msec
Message from Class Bluetooth: Could not connect to BT-Module with baudrate 230400 in 502.30080000000004 msec
Message from Class Bluetooth: Could not connect to BT-Module with baudrate 460800 in 502.62560000000002 msec
Client Mode
Program Message: Set Device Name: G120HDR
WARN: Total initialization time exceeds 30 seconds.
Enter Pairing Mode
The thread ââ (0x3) has exited with code 0 (0x0).
Enter Pairing Mode
Enter Pairing Mode
The program â[8] Micro Framework application: Managedâ has exited with code 0 (0x0).
the display is a button, when I press the screen, then enter pairing mode, but the BT-module still blink blue only and can not be found
