I used MSDeploy.exe to give my board an ip adress. I took 192.168.2.1. On my PC I took 192.168.2.2 - but I can’t ping the device - why? The IP Adress is also shown on the LCD display - but the ping works in no way.
Do the board and the PC have the subnet mask (probably 255.255.255.0) and the same gateway? Hm…also, not sure how your netork is configured, but .1 is generally what your router would use. Is the board plugged into the router or the PC?
If you are connecting the cable directly between ChipworkX and Your PC, make sure that you don’t need a cross-over cable. To make sure it is not the reason, just connect it through Ethernet switch.
Up to now I do not use a router/switch - I try to connect it directly to my notebook. I tried with a straight and a crossover cable - both is not working.
Greetings from Austria
Regards, Andi
EDIT: A short overview over my config:
CodeworkX Development System v1.2:
IP: 192.168.2.1
Subnetmask: 255.255.255.0
Std-Gateway: 192.168.2.254
