Can't mount my microSD Card.. PLEASE HELP
Hello everyone…
I have a C# .Net Micro Framework that look like this:
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace GadgeteerApp3
    public partial class Program
        private static double MOVEMENT_INDICATOR = 0.2F;
        private GT.StorageDevice sdKort;
            their name followed by a period, e.g.  button.  or  camera.
                timer.Tick +=<tab><tab>
                timer.Start();
             sdCard.MountSDCard();
             sdKort = sdCard.GetStorageDevice();
            Accelerometer accellerometer = new Accelerometer(1);
            accellerometer.ContinuousMeasurementInterval = new TimeSpan(0, 0, 0, 0, 200);
            accellerometer.MeasurementComplete += new Accelerometer.MeasurementCompleteEventHandler(accellerometer_MeasurementComplete);
            accellerometer.StartContinuousMeasurements();
        void accellerometer_MeasurementComplete(Accelerometer sender, Accelerometer.Acceleration acceleration)
           // Debug.Print("Z-acc:" + acceleration.Z);
           // Debug.Print("X-acc:" + acceleration.X);
           // Debug.Print("Y-acc:" + acceleration.Y);
            if (acceleration.Z < MOVEMENT_INDICATOR)
                // notify parents - got movement
                Mainboard.SetDebugLED(true);
                Thread.Sleep(5000);
                Mainboard.SetDebugLED(false);
                byte[] mp3er = sdKort.ReadFile("musik.wav");
                music.Play(mp3er);
I need to mount my MicroSD Card into my Mainboard, so i can play the music in the music module from the MicroSD Card.
But every time i try to start a debugging, I get this error:
SDCard ERROR : Unable to mount SD card. Is card formatted as FAT32?
And the SD Card IS formattet as FAT32…
What could the problem be…?
Please help me…
I have pasted the whole Outline from Visual Studio…:
Found debugger!
Create TS.
 Loading start at 805b980, end 808459c
   Assembly: mscorlib (4.2.0.0)     Assembly: Microsoft.SPOT.Native (4.2.0.0)     Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
   Assembly: Microsoft.SPOT.Graphics (4.2.0.0)     Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)
   Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0)     Assembly: Microsoft.SPOT.IO (4.2.0.0)
   Assembly: System.IO (4.2.0.0)     Assembly: Microsoft.SPOT.Hardware.OneWire (4.2.0.0)
   Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)     Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)
   Assembly: Microsoft.SPOT.Net (4.2.0.0)     Assembly: System (4.2.0.0)  Loading Deployment Assemblies.
Attaching deployed file.
   Assembly: GHI.OSHW.Hardware (4.2.3.1)  Attaching deployed file.
   Assembly: Gadgeteer (2.42.0.0)  Attaching deployed file.
   Assembly: System.Http (4.2.0.0)  Attaching deployed file.
   Assembly: GTM.GHIElectronics.SDCard (1.1.1.0)  Attaching deployed file.
   Assembly: Microsoft.SPOT.Net.Security (4.2.0.0)  Attaching deployed file.
   Assembly: GHIElectronics.Gadgeteer.FEZCerberus (1.1.1.0)  Attaching deployed file.
   Assembly: Microsoft.SPOT.Touch (4.2.0.0)  Attaching deployed file.
   Assembly: GTM.GHIElectronics.Music (1.1.1.0)  Attaching deployed file.
   Assembly: System.Net.Security (4.2.0.0)  Attaching deployed file.
   Assembly: GadgeteerApp3 (1.0.0.0)  Attaching deployed file.
   Assembly: Gadgeteer.SPI (2.42.0.0)  Attaching deployed file.
   Assembly: GTM.GHIElectronics.UC_Battery_4xAA (1.1.1.0)  Resolving.
Ready.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Graphics.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.TinyCore.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.OneWire.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\GHI Electronics\GHI OSHW NETMF v4.2 SDK\Assemblies\le\GHI.OSHW.Hardware.dll'
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies\.NET Micro Framework 4.2\le\Gadgeteer.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.Security.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Net.Security.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Http.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\SDCard\NETMF 4.2\le\GTM.GHIElectronics.SDCard.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Mainboards\FEZCerberus\NETMF 4.2\le\GHIElectronics.Gadgeteer.FEZCerberus.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Touch.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies\.NET Micro Framework 4.2\le\Gadgeteer.SPI.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Music\NETMF 4.2\le\GTM.GHIElectronics.Music.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\UC_Battery_4xAA\NETMF 4.2\le\GTM.GHIElectronics.UC_Battery_4xAA.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Users\sccm-unv\Desktop\GadgeteerApp3\GadgeteerApp3\bin\Debug\le\GadgeteerApp3.exe', Symbols loaded.
The thread '<No Name>' (0x2) has exited with code 0 (0x0).
Using mainboard GHI Electronics FEZCerberus version 1.1
Program Started
Failed allocation for 20 blocks, 240 bytes
The thread '<No Name>' (0x3) has exited with code 0 (0x0).
A first chance exception of type 'System.NullReferenceException' occurred in GadgeteerApp3.exe
Exception performing Timer operation
The program '[1] Micro Framework application: Managed' has exited with code 0 (0x0).
Thank you in advance…
Best regards…
Jacob Lau
Using code tags will make your post more readable. This can be done in two ways:[ol]
Click the “101010” icon and paste your code between the
 tags or...
Select the code within your post and click the "101010" icon.[/ol]
(Generated by QuickReply)
Check this reply from Justin:
http://www.tinyclr.com/forum/topic?id=8556&page=2#msg84904
@ Architect - Hej…
Sorry but the same error still occur when i debug the problem…
Any other suggestions…?
@ jacob.lau1992 - Hi Jacob, can you update you firmware to the latest and greatest and try again?
PS - Welcome :slight_smile:
Have you tried the code in the link I have provided?
@ Architect - Different boards Master Yoda
@ jacob.lau1992 - Try the code from Tutorial page then
//Mount the SD card
//Get the root directory
string rootDirectory = sdCard.GetStorageDevice().RootDirectory;
//Use Streamwriter to write a text file
StreamWriter textFile = new StreamWriter(rootDirectory + @ "\hello.txt");
textFile.WriteLine("Hello SD card");
textFile.Close();
//Use FileStream to read a text file
FileStream fileStream = new FileStream(rootDirectory + @ "\hello.txt", FileMode.Open);
//load the data from the stream
 byte[] data = new byte[fileStream.Length];
fileStream.Read(data, 0, data.Length);
fileStream.Close();
string text = new string(Encoding.UTF8.GetChars(data));
Debug.Print(text);
@ Architect - think it will still fail here:
//Mount the SD card
Looks like his firmware is 2 behind…
@ Justin - Hi Justin…
Do you mean the Mainboards firmware…?
@ Justin - Why? Looks up to date to me. GHI.OSHW.Hardware (4.2.3.1)
@ jacob.lau1992 - Can you try a different card?
@ Architect - 4.2.3.3 is the latest…hmmm or maybe not…
Wiki says 4.2.3.3 but looks like your right as dll is 4.2.3.1
*Edit - i just need to read proper like - as you were…
You could also try this code:
            Debug.Print("SD should be auto-mounted");
            //sdCard.MountSDCard();
            if (sdCard.IsCardMounted)
                VolumeInfo vi = sdCard.GetStorageDevice().Volume;
                Debug.Print(vi.Name);
                Debug.Print(vi.IsFormatted.ToString());
                Debug.Print(vi.FileSystem);
                Debug.Print(vi.TotalFreeSpace.ToString());
                string root = sdCard.GetStorageDevice().RootDirectory;
                Debug.Print("Root: " + root);
                Debug.Print("Program Finished");
                Debug.Print("SD Card Failed to mount!");
@ Architect - I have already tried three different MicroSD Card, and all of them has been formatted with FAT232 but causes the same error.
@ jacob.lau1992 - What size is the card, and what standard is it? (SD/SDHC/SDXC/MMC)
@ James - Hi James.
The card is MicroSDHC, and the size is 2GB…
@ stevepresley - Hi Steve.
When I try your code, I get this error, when I starts the debugging:
Program Started
Failed allocation for 66 blocks, 792 bytes
Failed allocation for 39 blocks, 468 bytes
A first chance exception of type 'System.OutOfMemoryException' occurred in mscorlib.dll
Failed allocation for 15 blocks, 180 bytes
Failed allocation for 13 blocks, 156 bytes
Failed allocation for 10 blocks, 120 bytes
An unhandled exception of type 'System.OutOfMemoryException' occurred in mscorlib.dll
@ Justin - Correct Justin.
The error still comming at the mount point
