Hey,
I use the GHI premium NETMF V4.2 SDK
But I don’t have a lot assemblies.
I only have the GHI.premium and the GHI hardware assemblies
I need the FEZ_cobra_GHIElectronics.NETMF.FEZ.dll
Microsoft.SPOT
mscorlib
Where can I find them? It must be version 4.2.0.0 or higher
Can you show the screenshot of your add reference dialog?
I see I have mscorlib. But I can’t add it. I click on it but nothing happen.
I have a program from someone als but he uses the old version. But I need the new ones but I can’t Instal them
Ok, the problem is that you are mixing assemblies from different SDKs. Cobra assembly is from 4.1. Other assemblies are from 4.2. What version of the firmware is on your board?
@ Architect - I updated my board to 4.2.11.1
Ok. Please don’t use Cobra assembly. It is from 4.1 SDK.
So I can’t work with 4.2? I need to do everything with 4.1?
So I better can use 4.1?
I use the touchpanel.
There has to be a webcam connected en 5 temperature sensors in a 1 wire connection and have to put everyting online so we can change sensors online
@ andre.m - I am looking for the 4.2 assemblies
You can use whatever matches the firmware on your device. It is 4.2 now. It is better to use 4.2 since it is the most recent release.
@ Architect - But where can I find the 4.2 assemblies?
@ serneels - In the add reference dialog that you showed earlier it shows that you have all the 4.2 assemblies.
The FEZCobra_GHIElectronics.NETMF.FEZ was from the program that I get from someone that made someting in 4.1. But I don’t have the assembly in my PC
That assembly is not in 4.2 anymore. Can you show your code?
//FEZ_Cobra_Console_Application_I2C on DS1631 sensor I2C1
namespace FEZ_Cobra_Console_Application_I2C
byte[] conT = new byte[1];
byte[] readrom = new byte[1];
byte[] rx = new byte[2];
I2CDevice.Configuration con = new I2CDevice.Configuration(0X49, 100);
I2CDevice IC1 = new I2CDevice(con);
I2CDevice.I2CTransaction[] Tcon = new I2CDevice.I2CTransaction[1];
I2CDevice.I2CTransaction[] tempread = new I2CDevice.I2CTransaction[2];
conT[0] = 0X51;
Tcon[0] = I2CDevice.CreateWriteTransaction(conT);
readrom[0] = 0xAA; //read temperature
tempread[0] = I2CDevice.CreateWriteTransaction(readrom);
tempread[1] = I2CDevice.CreateReadTransaction(rx);
IC1.Execute(Tcon, 1000);
Thread.Sleep(750);
IC1.Execute(tempread, 1000);
Debug.Print(“temperatuur I2C1: " + rx[0]);
Debug.Print(” ");
Thread.Sleep(1000);
You code is not using it.
You can safely remove:
and the reference to that assembly from the project.
