I’m here like every week.
After update my Cerberus mainboard following these instructions:
I was ready to debug a tiny program, however I could not. When I hit “deploy”, the message “Preparing to deploy assemblies to the device.” remains forever.
I’m sure that my program is not the source of the problem because it never runs.
This is it Your device has tinybooter loaded but no firmware on it yet. You now need to load the firmware, using mfdeploy, select files and click deploy.
BTW if you still have the issue after you follow GUS’s instruction try the following, it seems to work for me when my Spider starts acting up… i think it is a USB Driver issue…
once you see the message “Preparing to deploy assemblies to the device.” wait two seconds and hit reset on the board… which will allow it to continue…adn deploy…
You need to use MFDeploy to load the Cerberus firmware to the board the same way that you would with the Hydra. Go to MFDeploy then go to image files and select the image files from C:\Program Files (x86)\GHI Electronics\GHI OSHW NETMF v4.2 SDK\FEZ Cerberus\Firmware\tinyclr.hex. Once you deploy the files you should be good to go. The previous release of Cerberus did not include the TinyBooter. You cannot deploy to a device that only has TinyBooter.
