I download and installed all the packages by the FEZ Tutorial, but when I go to File->New Project and try to create a new Micro Framework->Consol Application I get the following error message:
"The project type isn’t supported by this installation"
Any suggestions?
I installed VS2008.
I remove it and reinstall it several times but without success.
I continue to receive this annoying message “The project type isn’t supported by this installation”
This is very frustrating that I bought FEZ domino kit and can’t do anything with it.
If you followed the tutorial and installed VS2008 then installed the Microsoft NETMF SDK 4.0 and then installed the GHI NETMF SDK then you will not have any problems.
If no luck then your windows installation is messed up, you will need to reformat your PC. Or try to remove all installations related to VisulStudio (including VB) then restart your PC and then try to go back to the tutorial and follow the instructions.
