Hi everybody, i have a simple problem, thought. I’ve created a class library project and now i have my dll file ready. I can add this library to the project in the solution explorer and also i can compile the project but when i try to start debugging i get an error message that says that it’s a problem with the hardware :o
I tried to add only de class “.cs file” and all works fine so i think the problem is in the dll assembly.
I’m watching this thread because I’m having this exact same problem with a Hydra project. I tried re-creating the project, restarting everything. Nothing works. The assembly worked fine in a Panda-II project but it will not deploy to Hydra.
Hi again, now i’m debugging the project using the emulator instead through the usb connection, when the dll reference is in the project i get the message - Assembly file " does not exist! Load failed.
And when i remove it from the project references the code runs well in the emulator.
