Cannot access Canvas Class - GHI Electronics
Using link from Google web search
http://www.ghielectronics.com/downloads/Glide/Library/html/74e0a2f7-f488-38ff-cbf5-214d1cf859a4.htm
Click Canvas Class … Page ‘flashes’ contents for about 1/2 second and then disappears (blank page) with only heading???
I do have popup blocking ON but I never have had any issues using any of the GHI pages before…
Gee… I needed to find something!
Hmm. Works great for me.
Try opening it from this page:
http://www.ghielectronics.com/glide
or using this link:
http://www.ghielectronics.com/downloads/Glide/Library/Index.html
@ andre.m - AND Architect
Well, I found the problem…
Microsoft sent a update for IE 10 that I am using. I installed that security update this morning.
I removed the update and now I can access the links. Not sure what to do about it though…
Guess I could try Chrome if I had too…
I forget the term used but the problem is like having a help file that needs to be opened for access using properties before it can be used.
With the new update the link looks like the attached image.
I see you have some extra add-ins too. These can interfere with the update as well.
@ Architect -
Yes I have some tool bars that I use. I on occasion use the McAfee safe search. I’ll remove all of them, redo the pdate and see what happens.
I just wanted to know if it was a known issue after the GHI web update.
Not pointing blame at anything. just wanted to know.
@ andre.m -
Thanks for the link… I never saw that post…
Not sure on how to set the … ‘is only viewable with the compatibility mode’ from a link…
@ willgeorge:
FYI I am using IE10 in normal mode (not in “Compatibility View” mode) without any issues.
@ Architect -
I reinstalled the update to IE 10 and the problem is back…
I set IE 10 to it’s default mode without ANY additions. The link still fails…
I’m running 64 bit windows 7… Yours?
This is the update that causes the problem - Internet Explorer 10 for Windows 7 for x64-based Systems
Although it is showing 4 updates of the same name with the same date… Guess I’ll remove them all and see what happens
64bit Windows 8.
