Can we use Singletons? Getting a Dispatcher error if I try and use a class as a Singleton
Hi all,
I am using Glide with gadgeteer and want to make use of the PressEvent/TapEvent/ReleaseEvent events on buttons but these events are static and so I can’t reference the objects I want to modify when buttons are pressed.
Therefore I turned this object’s class into a singleton which works fine when it is referenced in the static PressEvent etc. events but if I try and use it anywhere else it doesn’t work.
For example Class A is the singleton, if I do this in Class B:
ClassA classAObject = ClassA.Instance;
and the public property instance is defined as:
private static RepWorld instance;
        public static RepWorld Instance
            get
                if (instance == null)
                    instance = new RepWorld();
                return instance;
then I get the runtime error:
[quote]An unhandled exception of type ‘System.Exception’ occurred in Gadgeteer.dll
Additional information: Program must be instantiated on main (Dispatcher) thread.[/quote]
and the error in the console is:
Using mainboard GHIElectronics-FEZSpider version 1.0
    #### Exception System.Exception - 0x00000000 (1) ####
    #### Message: Program must be instantiated on main (Dispatcher) thread.
    #### Gadgeteer.Program::.ctor [IP: 0025] ####
    #### test.Program::.ctor [IP: 0004] ####
    #### test.Program::Main [IP: 000b] ####
A first chance exception of type 'System.Exception' occurred in Gadgeteer.dll
An unhandled exception of type 'System.Exception' occurred in Gadgeteer.dll
If I take out this
and just make
classAObject = null;
for now then the error goes away.
Has anyone else hit this problem with singletons?
Or does anyone know another way around the PressEvent/TapEvent/ReleaseEvent static event problem with referencing objects?
Thanks for your time,
Poncho
Can you please show your actual code?
Please take a look at this project as well:
http://www.tinyclr.com/codeshare/entry/349
Good example on how to use Glide with Gadgeteer.
Ah so the PressEvent/TapEvent etc. don’t have to be static? I just assumed they did because when you auto-complete the event handler it makes them static, now that they don’t have to be static it works fine.
Thanks for the help yet again Architech :slight_smile:
You are welcome!
