For school we have to develop a piece of software connected to a database server. The project before we all used a local access generated sql file to connect to.
Now we would like to use a dedicated database server. I know some of you have some servers running and I was hoping someone could help me out.
I would like to use one of these packages:
*Oracle
*MS SQL
*Access
Oh, I am sure that MySQL has ODBC connector/driver you just need to find and install it.
The site was just a quick google search. I have not used it myself.
Why not just install MS SQL Server Express on your PC? Its free and much easier to use than MySQL (IMHO.)
As for Access, it is still widely used and has its place. A friend of mine at the university had a student working on trying to set up a simple database in some idiotic Mac database program (Mac is naturally better at everythign my butt!). After a year they gave up as it would never work right. The same student recreated the whole thing in Access in about three weeks. It works great for their in house use and has a low administrative overhead.
By “dedicated database”, I assume you a dedicated server.
If so, can’t you just install MS SQL Express on a dedicated system and use that as your server?
You could potentially just copy your existing mdf & ldf files to that new system and attach the database. There are version issues sometimes, thus the “potentially”.
So there is a group of you needing access to the same DB? You don’t have to have a ‘server’ to use/share MS SQL Express. If you have a PC that everyone can connect to that is all that is needed.
None of our PCs on campus have external access anymore so I can’t help out.
Two free full featured options from MS. SqlExpress or Sql Compact.
Sql compact is an in-proc database, so it runs in process with your app and is deployed with your app. Good for many senerios. SqlExpress would be next step up. Both very good, well documented and supported. Also both support ADO.Net entity framework. For that EF alone, I would go with one of those. They also blend in nicely with ADO.Net Data Services and surface your database easily with REST api.
So I am thinking that Robert’s real request is that he needs a known target that stays “alive” and fixed on the network, for his distributed team to use. Options to have it local probably aren’t going to get you further, are they? Have you thought about using Dynamic DNS and client software for a PC that might move about?
You can use Compact over net, you just host it in a server wrapper such as DataServices or IIS ASP.Net. This 2nd tier business layer is typical and better then direct access to an open native sql port.
That was a very good idea. I have been using DynDNS.org for years to have a URL that always points to my home desktop. I also use them now for domain registrations.
