I only have a board FEZPanda_II and I use the code on the www.tingyclr.com to debug. But CAN1 TXD can not send any message out. The debug window always display “BusOff error. Reset CAN controller”.
Must I have two nodes so that it can run successfully?
// Messages list
static CAN.Message[] msgList;
Utility.SetLocalTime(new DateTime(2011, 2, 14, 0, 0, 0));
int T1, T2, BRP;
BRP = 24;
T1 = 15;
T2 = 8;
CAN can = new CAN(CAN.Channel.Channel_1, (uint)(((T2 - 1) << 20) | ((T1 - 1) << 16) | ((BRP - 1) << 0)));
msgList = new CAN.Message[100];
for (int i = 0; i < msgList.Length; i++)
msgList[i] = new CAN.Message();
// example for sending one message
// msg ID
msgList[0].ArbID = 0x55;
msgList[0].Data[0] = 1;
msgList[0].Data[1] = 2;
msgList[0].Data[2] = 3;
msgList[0].Data[3] = 4;
msgList[0].Data[4] = 5;
msgList[0].Data[5] = 6;
msgList[0].Data[6] = 7;
msgList[0].Data[7] = 8;
// Send the 8 bytes for example
msgList[0].DLC = 8;
msgList[0].IsEID = false;
msgList[0].IsRTR = false;
// Send one messages
int numberOfMessagesPosted = can.PostMessages(msgList, 0, 1);
// subscribe to events
can.DataReceivedEvent += new CANDataReceivedEventHandler(can_DataReceivedEvent);
can.ErrorReceivedEvent += new CANErrorReceivedEventHandler(can_ErrorReceivedEvent);
// sleep forever
static void can_DataReceivedEvent(CAN sender, CANDataReceivedEventArgs args)
Debug.Print(">>> can_DataReceivedEvent <<<");
// read as many messages as possible
int count = sender.GetMessages(msgList, 0, msgList.Length);
for (int i = 0; i < count; i++)
Debug.Print("MSG: ID = " + msgList[i].ArbID + " at time = " + msgList[i].TimeStamp);
static void can_ErrorReceivedEvent(CAN sender, CANErrorReceivedEventArgs args)
Debug.Print(">>> can_ErrorReceivedEvent <<<");
switch (args.Error)
case CAN.Error.Overrun:
Debug.Print("Overrun error. Message lost");
break;
case CAN.Error.RXOver:
Debug.Print("RXOver error. Internal buffer is full. Message lost");
break;
case CAN.Error.BusOff:
Debug.Print("BusOff error. Reset CAN controller.");
sender.Reset();
break;
