Can I Power FEZ Spider, USB Client DP Module with 8 AA 1,2V 1900mAh?
I have a FEZ Spider Starter Kit,
can i Power the USB Client DP Module with 8 AA 1,2V 1900mAh Rechargeable Batteries?
So if i calculate right i should have 9,6V and that should work?
Or is the 1900mAh to much?
I’m sorry if this sounds like a stupid question but i am new to this.
See attachments.
Thanks,
Alex
it will work fine
the 1900mah is the capacity of the batteries, not the load
you can use this one:
http://www.ghielectronics.com/catalog/product/394
Thanks for the really quick answer.
@ VB-Daniel: yes, i saw that, but it’s 28$, if i buy the Batterie case and the cable from my pitures its ~4€
So just to be sure, it doesn’t matter how much mAh the batteries have, so i could also use 8 2700mAh Batteries?!
mAh is how long the battery will last for
