Dear all,
I have the following very simple code to stream video to the LCD display in a Fez Spider GHI kit:
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace CameraTest
public partial class Program
timer.Tick +=<tab><tab>
timer.Start();
camera.BitmapStreamed += camera_BitmapStreamed;
camera.CameraConnected += camera_CameraConnected;
button.ButtonReleased += button_ButtonReleased;
void button_ButtonReleased(Button sender, Button.ButtonState state)
Debug.Print("Button pressed");
void camera_CameraConnected(Camera sender, EventArgs e)
Debug.Print("Camera connected");
camera.StartStreaming();
void camera_BitmapStreamed(Camera sender, Bitmap e)
displayTE35.SimpleGraphics.DisplayImage(e, 0, 0);
The code works fine. However, after adding the ethernetJ11d module to the project and consequently this line is added to Program.generated.cs:
The camera does not connect, or rather, the callback function [em]camera_CameraConnected[/em] never gets called. Therefore, I can't use the camera while ethernetj11D is included in the project (I get camera not connected exceptions).
I am using Visual Studio 2012 Express on Windows 7 64 bits. This is the firmware I have:
Loader (TinyBooter) version information:
4.3.4.0 on this computer.
4.3.4.0 on this device.
>>> The Loader (TinyBooter) is up to date. <<<
Firmware (TinyCLR) version information:
4.3.6.0 on this computer.
4.3.6.0 on this device.
>>> The Firmware (TinyCLR) is up to date. <<<
Any help will be greatly appreciated!
Kind regards,
Federico
