is it possible to plug the “camera module” directly to the “FEZ mini Robot kit”?
(I need to plug a “camera” and a “distance sensor” at least, but the more the merrier )
Or is additonally another “mainboard module” needed to plug the camera to the robot kit? Which module would you suggest?
Sorry, I dont exactly understand.
Would this gadgeteer camera http://www.ghielectronics.com/catalog/product/283 work directly with the “FEZ mini robot kit”? Or do I need to plug the camera to another gadgeteer module, and plug then the gadgeteer module to the “FEZ mini robot kit”?
The gadgeteer modules will only work with gadgeteer.
If you need a camera for your robot, you could use the gadgeteer for capturing images, but that would not be ideal and expensive also.
Maybe (!) a serial camera would work, but I am not sure if the mini has enough memory for that?
