Just ordered a 6 pin version of that…
6 pin? I thought I needed 10 pins? What are you interfacing with it?
The touch is 6 pin I think…
I think we have different panels then. Once we figure out a few, then we’ll have a solution to support more displays. Going to be another month before I get that breakout board. Sigh.
Why 10 pins? Did they check the pinout?
I usually see
GND
VCC
SDA
SCL
RST
INT
You could make a simply double sided PCB to do the conversion. JLCPCB is cheap for these.
I’m a long way from being able to do that Dave.
It would be a perfect first project to learn PCB design
Ideal and not too difficult to deal with high speed lines either. The RGB interface, unlike LVDS, doesn’t require length matching and the only line to take care with is the clock. Least number of via’s the better.
Oh, no I just need an interface board for the smaller 10 pin cable for the touch display.
