I am truing run a project from here - http://blogs.msdn.com/b/net_gadgeteer/archive/2011/12/19/why-not-while-true.aspx#comments using the button on the FEZ Cerberus board. I get the error that "The name ‘button’ does not exist in the current context ". Below is the code with the namespaces and attached the references. BTW - this is a problem I have all the time where I am not sure which namespaces and references should be included. Any idea?
using System.Collections;
using Microsoft.SPOT.Touch;
using Microsoft.SPOT.Net;
using System.IO.Ports;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace ButtonANDLight
public partial class Program
GT.Timer ledBlinkTimer = new GT.Timer(1000);
button.ButtonPressed += new Button.ButtonEventHandler(button_ButtonPressed);
ledBlinkTimer.Tick += new GT.Timer.TickEventHandler(ledBlinkTimer_Tick);
ledBlinkTimer.Start();
void ledBlinkTimer_Tick(GT.Timer timer)
if (button.IsLedOn == true)
button.TurnLEDOff();
button.TurnLEDOn();
void button_ButtonPressed(Button sender, Button.ButtonState state)
Debug.Print("Button Pressed");
