Hi
I add some filtering in FT5xx6 library to prevent firing many events on single touch.
Also found that the flags were wrongly assigned to the touch types.
it is now: flag = 0 for TouchDown ; flag = 1 for TouchUp ; flag = 2 for TouchMove
but it should be: flag = 0 for TouchMove; flag = 1 for TouchUp; flag = 2 for TouchDown:
Partial code with my filters and corrected flags assignment:
try
this.i2c.WriteRead(this.addressBuffer, 0, 1, this.read32, 0, this.SampleCount * 6 + 2);
if (this.read32[1] != 0 && this.GestureReceived != null)
this.GestureReceived(this, new GestureEventArgs((Gesture)this.read32[1]));
//We do not read the TD_STATUS register because it returns a touch count _excluding_ touch up events, even though the touch registers contain the proper touch up data.
for (var i = 0; i < this.SampleCount; i++)
var idx = i * 6 + 3;
var flag = (this.read32[0 + idx] & 0xC0) >> 6;
var x = ((this.read32[0 + idx] & 0x0F) << 8) | this.read32[1 + idx];
var y = ((this.read32[2 + idx] & 0x0F) << 8) | this.read32[3 + idx];
//multitouch filter
if (flag==touchFlag && Math.Abs(x - filterX)<8 && Math.Abs(y - filterY) < 8 && (DateTime.Now.Ticks-touchTimeStamp)< TimeSpan.TicksPerSecond )
return;
if (x!=4095 && y!=4095)
filterX = x;
filterY = y;
touchTimeStamp = DateTime.Now.Ticks;
touchFlag = flag;
if (this.Orientation != TouchOrientation.Degrees0)
// Need width, height to know do swap x,y
if (this.Width == 0 || this.Height == 0)
//this.interrupt.ValueChanged += this.OnInterrupt;
return;
switch (this.Orientation)
case TouchOrientation.Degrees180:
x = this.Width - x;
y = this.Height - y;
break;
case TouchOrientation.Degrees270:
var temp = x;
x = this.Width - y;
y = temp;
break;
case TouchOrientation.Degrees90:
var tmp = x;
x = y;
y = this.Width - tmp;
break;
//(flag == 0 ? this.TouchDown : flag == 1 ? this.TouchUp : flag == 2 ? this.TouchMove : null)?.Invoke(this, new TouchEventArgs(x, y));
(flag == 0 ? this.TouchMove: flag == 1 ? this.TouchUp : flag == 2 ? this.TouchDown: null)?.Invoke(this, new TouchEventArgs(x, y));
if (flag == 3)
break;
catch
return; // Don't stop main application
