I have tried building the Ethernet firmware by changing the TinyCLR.proj file per the post on building the Hydra firmware.
As expected that throws a build error that the LR_TARGETLOCATION is too small.
It builds with that increased to a code size of ox08000
But it doesn’t run. A quick look at the .map file reveals that
Code (inc. data) RO Data RW Data ZI Data Debug
454592 195716 43348 2836 62296 92704 Grand Totals
454592 195716 43348 2836 62296 92704 ELF Image Totals
454592 195716 43348 2836 0 0 ROM Totals
Total RO Size (Code + RO Data) 497940 ( 486.27kB)
Total RW Size (RW Data + ZI Data) 65132 ( 63.61kB)
Total ROM Size (Code + RO Data + RW Data) 500776 ( 489.04kB)
This won’t fit in ER_RAM_RW as that it in CCM after the stack which is set to 16K leaving 48K; so this will go over. Indeed looking at the map shows it placing items outside the address range of CCM.
Obviously the build uses more memory than we have. I have used NETMF PK4_2 with ghiopensource-22347. The lwip_selector.h file is not altered and I notice is the same values as the NetduinoPlus2 source.
Was the GHI OSHW Ethernet firmware built with any special options or scatterfiles? What size is the ER_RAM_RW region?
The non Ethernet firmware builds fine.
I have not built the firmware with Ethernet support so I cannot provide any insights on the build settings. I believe GHI uses the RVDS to build the firmware.
Gus, I am using MDK-ARM 4.20 (I state 4.13 for the build as NETMF has everything set up for that)
My point is the RW Data & ZI Data is too large and as they are variables are they not the same size (pretty much) whether MDK or GCC?
Its the sockets_pal_lwip.lib that takes so much space
I have manged to create a working version by hacking the values in [quote]C:\MicroFrameworkPK_v4_2\DeviceCode\pal\net\Network_defines_lwip.h[/quote]
You use a standard build, like me, so I shouldn’t have to do that.
What I don’t understand is how you are using just lwip_selector.h with the standard PK4_2 and not getting such a large RW Data & ZI Data
Any chance of a map file for your OSHW build? Thanks
OK Mystery solved.
I had assumed that the stock provided scatterfiles for MDK and RVDS would have the same memory scheme, espescially as the compiler is the same, MDK uses RVDS.
Surprisingly, to me anyway, the GHI provided FEZCerbersus scatter files have different memory allocations for MDK and RVDS. Gus any reason why?
The RVDS allocates much more Flash and RAM to TinyCLR. All of the CCM is dedicated to TinyCLR.
So for non Ethernet code, which fits in the MDK memory scheme, you have 128K more space for deployed code and 23K more “Ram” for the deployed solution if you build with the MDK scheme.
