Une exception de première chance de type ‘System.ArgumentException’ s’est produite dans Microsoft.SPOT.Hardware.dll
Une exception non gérée du type ‘System.ArgumentException’ s’est produite dans Microsoft.SPOT.Hardware.dll
Uncaught exception
public int ReadRegister(byte address) //n register
transactions = new I2CDevice.I2CTransaction[2];
byte[] WriteData = new byte[1] { address };
transactions[0] = I2CDevice.CreateWriteTransaction(WriteData);
byte[] ReadData = new byte[1];
transactions[1] = I2CDevice.CreateReadTransaction(ReadData);
if (i2cBus.Execute(transactions, TRANSACTIONEXECUTETIMEOUT) != 0) <--- :o Boum !!
I think we need to see more of your code. We need to know what address you’re using, where you’re creating the I2CDevice.Configuration.
I would also suggest that you take simple steps first - instead of abstracting the read of the register, just write a short sequence of commands that will report back a few of the different registers, like software version and bearing. That way you can prove that you have figured out how I2C works and then how to talk to the device. See the tutorial [url]http://wiki.tinyclr.com/index.php?title=I2C_-_EEPROM[/url] for I2C general setup code.
Why oh why do vendors still do this :wall: Please folks, get with the program, only talk about 7-bit addresses and use them everywhere !!!
If you search the interwebs for this device, the vendor has talked about the address value [url]http://www.robot-electronics.co.uk/htm/arduino_examples.htm[/url] As Bec says, the 8-bit address can be found by shifting one bit, but still I would prefer to talk about the device as having address of 0x60.
