First thing is - I wouldn’t panic. Several posts on the same topic won’t get you an answer any quicker.
I can’t help with getting this set up but I wanted to note that this is a low-volume product that has a small following, so it may be some time before you get too much more feedback.
FYI - I’ve setup the GHI chain for the G30, boot loaded the G30 firmware
, created some simple C# programs for a console app and everything works fine.
Installed the Scratch Gateway, firmware update, installed the Scratch 2.0, everything works
except none of the LEDS/Temp/Accel etc. works.
I’ve been in this business for many years so I am no amateur however I can’t peek inside
unless I have source or more information.
It’s too bad because this product was exactly what I was looking for to round out my course offerings
but it seems far too immature at this point to actually use yet.
I haven’t read all of the other posts yet and have a few other fish to fry at the moment, but one thing you can try is to open up the Windows Device Manager and expand the COM ports tree. Find the COM port for the brainpad, right click on it and select Properties. Set 115200,8N1 as the default. This may unblock you.
In some cases, the driver defaults to 9600 8N1 and that introduces a ton of lag (many seconds) and the sensors and LEDs appear not to work.
