Justin
July 10, 2013, 8:02am
1
Justin
July 10, 2013, 9:22am
4
@ Gus - Sorry, couldn’t help myself…
Going to whip up a demo controlling a Cerbot using the Tablets Accel / Mag
When that is done i will add it to code share etc…
I think many would want to see both sides of the code to understand how to handle communication between a device and a PC.
HughB
July 10, 2013, 12:20pm
6
@ Justin - Really smart demo man! Kudos.
which bluetooth module you using…cool demo
Justin
July 10, 2013, 12:37pm
8
Thanks Justin…did you create your own drivers? DId you use the BGScript or is it pretty easy to use?
Justin
July 10, 2013, 1:12pm
10
@ zigbox - BGScript, pretty easy to use.
@ Justin - That is an excellent demo… I hope you have a few spare BT modules, I definitely want to order one.
Justin
July 10, 2013, 1:22pm
12
And i hope you have a TI CC Debugger
Clearly I have much to learn about Bluetooth… I had to google TI CC Debugger. OK, I will stick to just being impressed with the cool demo
Justin
July 11, 2013, 9:15am
14
Justin, how did you connect it to the uP. Can i connect the BLe112 directly to my computer com port? Do you have a schematic?
Justin
April 21, 2014, 3:41am
17
@ anthonys - My module uses Uart but you can directly connect the BLE112 to USB and it will show as a com port. It just requires 3 resistors a couple of caps and the correct firmware.
What are you trying to achieve?
Just want start playing with a ble112 I have. Does the default firmware support USB? want program one to do some automation…you know…the fun stuff
Justin
April 21, 2014, 4:15am
19
You will need to flash it with a cc debugger to turn on usb support then away you go.
There are example projects and schematics in the Blue giga SDK.
