When I first started playing with RLP,
it took me a while to figure out how to get it set up.
With the help of people here I managed to get it working
I wanted to do something in return,
so I created a guide covering the installation of yagarto,
setting up the build environment, writing a simple RLP library
and consuming it from C# without going into the technical details behind it all.
I have a question. Can the RLP code be debugged using Visual C#? In other words will the Visual C# debugger step into the RLP code? If not then how do you debug it?
