Hey guys,
According to the G120 manual, this code should work, but does not.
I was able to blink the led in 4.2, but no luck since updating to 4.3
// OutputPort LED = new OutputPort(Cpu.Pin.GPIO_Pin0, false);
OutputPort LED = new OutputPort(G120.P0_17, true);
Thread.Sleep(200);
for (int i = 0; i < 200; i++)
LED.Write(true);
Thread.Sleep(200);
LED.Write(false);
Thread.Sleep(200);
using GHI.Pins;
LED.Write(true);
Thread.Sleep(500);
LED.Write(false);
Thread.Sleep(500);
whoops … This may not be clear, but examples in that manual are not for Cobra II; they are for G120 SoM. In the example sited, the assumption is that the designer has attached an LED to the GPIO pin.
I tried both definitions in my attempt to blink the LED.
and
Neither definition would change the state of the LED
If you can tell me the pin number of the LED on the Cobra II, i will try again.
Thanks for the quick reply.
Mike & Dave,
Thanks for the good suggestions and thoughts.
I am trying to drive the LED on the Cobra II.
Thanks Guys, I must admit that I seldom think about looking at the schematic. I figure the board s already build so why do I need the schematic! Wrong! A lesson learned for the future! Larry Scott
