Beta, Beta, Beta!
Just saw this pop up under Beta downloads,. Of course I have a teleconference in a couple minutes so I can’t play yet :frowning:
[quote]SDK Version 1.0.12 February 21, 2011
�USBizi (FEZ Mini, FEZ Domino, FEZ Rhino, FEZ Panda) V 4.1.4.0
�EMX (FEZ Cobra) V 4.1.4.0, TinyBooter V 4.1.3.0
�ChipworkX V 4.1.4.0 TinyBooter V 4.1.3.0
�GHI NETMF Library V 4.1.4.0
�Release Info
�USB and SD storage optimizations
�New CAN driver. Class members changed. Some of the new features: optimized batch message reading, events. TimeStamps and filters.
�RLP support
�RLP native tasking support
�Support for more USB Joysticks types. Hat switch functionality is improved.
�Update to USB Host CDC and handshake support
�Update to USB Client CDC write issues
�Networking Wiznet optimizations. Speed is about 3 times faster.
�Added ParallelPort support
�Added PinCapture support
�Added 4KB InternalFlashStorage for the user under GHIElectronics.NETMF.Hardware
�Added USBHostController.Reset method
�OutputCompare now has a blocking option for more accurate timings
�Wiznet W5100 support for DHCP Client and HTTP
�Fixed: Serial port crashes on power up, hangs when flushing TX data with hardware handshaking enabled, RTS signal rate and others.
�Fixed: File system corruptions
�Fixed: Analog scaling problems
�Known Issues
�RSA Decrypt fails for certain input lengths.
�Wiznet W5100 DHCP does not renew when it expires
EMX (FEZ Cobra)
�Release Info
�Support to force EWR flushing using GHIElectronics.NETMF.System.Util.FlushExtendedWeakReferences
�Support for more USB Joysticks types. Hat switch functionality improved.
�Fix to CANxtra graphics
�Fixed: Blocking delays every 5 seconds
�Known Issues
�SSL works correctly. However, certification verification can fail.
�TimeService SNTP time update can crash
ChipworkX
�Release Info
�Known Issues
�SerialPort hardware handshaking is not supported.
[/quote]
Sweet!!!
Waaaaait! Does this mean RLP is unlocked on Cobra now?!
Cobra Shmobra, looks like it’s on Panda and Domino (and Mini et al) too !!! Schwing !
Time to head back into my cave and make, shall we say, major Pxyis updates
I told you you will love the new feature :slight_smile:
See here please http://www.tinyclr.com/forum/12/2491/
Now thats what I call an SDK update.
I’m already overly pleased with the panda… now with RLP, Get in.
Cheers Ian
Gus,
the first link on the download page “First, update your device” points to the wrong video (FEZ First Power up [url]- YouTube).
It should be Updating Firmware on FEZ [url]- YouTube
