Being used to working with the ChipworkX I learned a hard lesson about restricted resources today
Anyway,
At first my elf image was about 52kb, then after passing the -Os and -g0 options to the compiler,
I got reduced to about 39kb.
Later I noticed that the use of constants and the use of long variable names also increases the size of the image. The constants… that made sense… but the variable names?
Why doesn’t the compiler simply convert them to something very short so the code can stay clean
while keeping things small ?
I mean is this why C developers write ugly looking code?
So I have a few questions here
What can I do to keep my elf image as small as possible, do I really need to write ugly code?
What is the best way to load the bytes of the elf image, as I’m always running out of memory. Even if I use Debug.GC(true) before and after loading the bytes using File.ReadAllBytes
What is the max size of en elf image that can (in your experience) be loaded on a Fez Panda II
Let me combine your questions in one answer. Panda (USBizi) has 40KB of RAM, ChipworkX 64000KB of RAM. So it maybe necessary to think really deep into how to optimize everything, even in making hte code not so pretty Even if you were able to load the RLP bits into RAM, there is only 10KB reserved on USBizi for RLP.
I think I can work around that if I have to.
I’m just surprised the compiler doesn’t change the variable names,
and now I’m wondering if after all these years I’ve finally figured out why C developers write code that looks just … ugly
Anyway, given what I will use the Panda for, I might not need RLP at this time.
Oh btw… I got a full green light to build our next projects on top of GHI hardware (mainly the chipworkX for large traffic guidance systems and the panda for traffic signs).
With a little effort you could import the binary directly into usbizi not the elf, but you must provide the address of each function. This should reduce size a lot.
c:/yagarto/bin/../lib/gcc/arm-none-eabi/4.6.0/../../../../arm-none-eabi/bin/ld.exe: ../Resources/RedpineWifiDriver.elf section `.bss' will not fit in region `SDRAM'
c:/yagarto/bin/../lib/gcc/arm-none-eabi/4.6.0/../../../../arm-none-eabi/bin/ld.exe: region `SDRAM' overflowed by 8 bytes
If I tell the linker to remove all symbols ( -s ), it doesn’t change anything. Is it possible to optimize this problem ?
I want to try direct binary, but, is it the elf file that we have to copy with GHIElectronics.NETMF.Hardware.LowLevel.AddressSpace class ?
