With a G120, if i program the module over serial, the program load is successful. If I load from a USB drive, with SystemUpdate, I get the following error:
[quote]GHI Electronics, LLC
G120™ GHI low-level loader Rev 1.01
Bad Memory Detected!! Please Contact GHI[/quote]
GHI?
@ stevepx -
What do you mean “with SystemUpdate” ?
I mean when I use the SystemUpdate class from the GHI.Premium.System namespace.
@ stevepx -
You mean IFU?
I don’t think IFU caused that problem!
Show us your code, please?
And after the bug happened, using serial then it comes back normally?
@ stevepx -
You mean IFU?
Yes, IFU leaves this module blank and the low level loader generates the error message I included in the first post.
This code works with no error on other modules, only this one, so far, produces an error.
Here is the code (modified from the example):
using System.IO;
using Microsoft.SPOT.IO;
using GHI.Premium.Hardware.LowLevel;
using GHI.Premium.System;
using wd = GHI.Premium.Hardware.LowLevel.Watchdog;
namespace GHITest
class Update
public Update(String fileName, Lcd8Wire lcd)
lcd.SendAllLines("Updating...", "", "", "");
SystemUpdate.Initialize(/*SystemUpdate.SystemUpdateType.Config |
SystemUpdate.SystemUpdateType.Firmware |*/
SystemUpdate.SystemUpdateType.Deployment);
LoadDataFromUsb(fileName, SystemUpdate.SystemUpdateType.Deployment);
if (SystemUpdate.CanUpdate)
lcd.SendAllLines("Update successful,", "restarting...", "", "");
wd.ResetCounter();
SystemUpdate.FlashAndReset();
lcd.SendAllLines("Update FAILED,", "Shutting down...", "", "");
wd.ResetCounter();
Thread.Sleep(5000);
Program.ShutDown();
static void LoadDataFromUsb(string filename, SystemUpdate.SystemUpdateType ifutype)
int rest;
byte[] hex;
long len;
int blocknum;
FileStream fs = null;
const int BLOCK_SIZE = 10 * 1024;
try
fs = new FileStream(filename, FileMode.Open, FileAccess.Read, FileShare.Read);
len = fs.Length;
blocknum = (int)len / BLOCK_SIZE;
rest = (int)len % BLOCK_SIZE;
hex = new byte[BLOCK_SIZE];
for (int i = 0; i < blocknum; i++)
wd.ResetCounter();
Debug.Print("Loading file " + filename + ", block " + i + "/" + blocknum);
fs.Read(hex, 0, BLOCK_SIZE);
hex = Program.DecryptData(hex);
SystemUpdate.Load(ifutype, hex, BLOCK_SIZE);
Debug.Print("Loading file " + filename + ", block " + blocknum + "/" + blocknum);
fs.Read(hex, 0, rest);
wd.ResetCounter();
SystemUpdate.Load(ifutype, hex, rest);
catch (Exception ex)
Debug.Print(ex.Message);
finally
if (fs != null)
fs.Close();
fs.Dispose();
fs = null;
hex = null;
wd.ResetCounter();
Debug.GC(true);
Sambo
June 20, 2014, 7:20pm
#6
[quote=“stevepx”]This code works with no error on other modules, only this one, so far, produces an error.
[/quote]
So is it correct to conclude that only one of a number of G120 modules gave you this bad memory error?
Interesting to know that there could be a memory problem in the G120 units and you stumbled on way to detect that! I wonder if it was the external RAM?
It’s a good idea for someone (not me!) to write a diagnostics code that will check all memory (internal and external RAM, Flash, and EEPROM) in any module or main-board for errors, like the diagnostics programs we used to use to check PC memory.
