Back to basics
I have this code for the cerbuino
            OutputPort led = new OutputPort(Cpu.Pin.GPIO_Pin13, true);
I shove an led in the digital pin 13 and one into ground
I checked both ways, its not a faulty led. its not in the wrong orientation, and I don’t understand how I cannot figure out how to turn on a damn LED!
Update: Error
first, when the ProgranStart method is exited, the Output goes out of scope, and gets disposed.
Also, check to see if the pin that is giving you the exception is not already in use.
@ Mike - I want to power the pin that would be digital pin 13 on the arduino
This is on the cerbuino bee.
Would that be the gpio 13 pin?
Check out this doc on locating I/O pins:
https://www.ghielectronics.com/docs/6/locating-ios
Also this, on Digital Outputs:
https://www.ghielectronics.com/docs/7/digital-outputs
You need to start with the schematic for the Cerbuino Bee (or whatever board you may be working with), and determine what pin you’re dealing with. Schematic for the Cerbuino Bee is here:
http://www.ghielectronics.com/downloads/schematic/FEZ_Cerbuino_Bee_SCH.PDF
I’ve snipped the relevant section and highlighted what you need to look for, in the attached pic.
Once you have the pin info (in this case, PB3, you can create your digital output like so in Program.cs (note that you’ll need to add a reference to the GHI.Pins assembly for GHI.Pins.Generic.GetPin to resolve):
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace Pin13Blink
    public partial class Program
        static OutputPort blinkPort;
        bool isLEDOn = false;
            blinkPort = new OutputPort(GHI.Pins.Generic.GetPin('B', 3), isLEDOn);
            GT.Timer timer = new GT.Timer(1000);
            timer.Tick += timer_Tick;
            timer.Start();
            isLEDOn = !isLEDOn;
            blinkPort.Write(isLEDOn);
Note that for a pin PB3, you don’t include the “P”, and the call to GetPin takes a Char, not a string, so the letter portion of the pin label should be in single quotes, not double quotes.
Hope that helps.
@ devhammer - YOU ARE AWESOME
:dance:
It works!!!
Im surprised how many lines this took but ohwell, atleast you had intellisence with the code
My pleasure. Next time, though, you get to look up the pin on the schematic. :smiley:
While I included the entire Program.cs, pretty much all but 5 lines of code is boilerplate. Or 11 lines if you include all the timer code (including the curly braces).
Not a lot of code at all, given that you’re doing non-Gadgeteer stuff inside a Gadgeteer project. :wink:
what, two lines is hard ?
<snip>
