AutoResetEvent locks main thread
Upgraded to latest premium SDK and now I have problem with follwing code
        private void TriggerThread()
            try
                    if (_pollEnable)
                        // Poll the trigger input
                        _fireEventSignal.WaitOne(50, false);
                        _fireEventSignal.WaitOne();
                    if (Trigger != null)
                        if (_triggerPin.Read())
                            if (_highRequest != null && _lastState != 1)
                                Trigger(_highRequest);
                            _lastState = 1;
                            if (_lowRequest != null && _lastState != 0)
                                Trigger(_lowRequest);
                            _lastState = 0;
            catch (Exception ex)
                Log.LogHandler.LogException(ex);
            finally
                if (_fireEventSignal != null)
                    _triggerPin.EnableInterrupt();
Problem is that _fireEventSignal.WaitOne() will freeze the main thread which started the TriggerThread method.
_triggerThread.Start();
I didn’t have this problem in 4.1.
need a complete sample of code which displays your problem to make any worth while comment
this is the calling method
        public TriggerInfo(Cpu.Pin pin)
            _triggerThread = new Thread(new ThreadStart(TriggerThread));
            _triggerThread.Priority = ThreadPriority.Lowest;
            _lastState = -1;
            _pollEnable = false;
            _fireEventSignal = new AutoResetEvent(false);
            try
                _triggerPin = new InterruptPort(pin, false, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeBoth);
                _triggerPin.OnInterrupt += new NativeEventHandler(TriggerPinInterrupt);
                _triggerPin.DisableInterrupt();
                _interruptActivated = true;
                // The pin doesn't support interrupt need to add poll method
                _interruptActivated = false;
I asked for a complete sample. you are giving me snippets. I was going to try to reproduce the problem.
I have to go now, and will not be available. maybe someone else can help you.
I still have problem with this issue in 4.2.
The problem seams to be when I call a method which have a AutoResetEvent.WaitOne inside.
There are two instances of this class and one is called from a thread and the other from a timer.
The deadlock happens when the the first caller is done with WaitOne and leaves the method while the other one is still in WaitOne.
I have a 1000ms timeout in the WaitOne call.
After 60 seconds the G120 restarts in this state.
This problem is realy hard to debugg, when I pause VS in deadlock the G120 is restarts.
sounds like you know enough of the scenario now to be able to create a simple repro project that someone else can try…
