After I read Foekie’s tutorial on XBee. I decided to do bring my XBee to life after collecting dust on the shelf for a while.
And I was able to set my XBee modules to talk to each others.
Yet it also cross platform, between Arduino and FEZ Domino.
One Xbee hooks up to Arduino as a Transmitter. The other hooks up to FEZ Domino, plus Graphics 128x64 LCD, to display the message.
These XBee Modules I bought a long time ago and was only used in the Arduino environment.
Foekie’s tutorial didn’t mentioned about the way to use AT Commands to configure XBee module.
So I think it might be benefit to others who would like to use XBee and want to set up XBee real quick without uploading the XCTU application from Digi’s.
I thought, what you’re going to do with that Section is only to purely use XCTU utility application, as the name imply.
The method I use to configure the XBee is not involved with XCTU. I just use Tera Term and AT Commands to configure the XBee.
I’m not aware that it will be the same procedure that you’re going to use in
[quote]How to configure Xbee using X-CTU?
Coming soon…
[/quote]
Anyhow, I can help you write up this Section in your tutorial (How to configure XBee using XCTU?).
I have XCTU application and know how to use it.
What do you thing??
