Hello. I am getting an ***** ASSERT ***** on the screen of my EMX Development System
I found an old post:
Was running the latest tweaked version of my app described in this thread: http://www.tinyclr.com/forum/21/4703/
and it appeared that the code executed successfully, but then I noticed that the following appeared on my LCD:
***** ASSERT *****
Any clues on what that means?
Thankfully, when I re-run the app, the message goes away, so doesn’t look like I borked anything permanently
Reply from GUS:
This should not happen and if it did we need the simplest possible program you can provide that repro this so we can look into it.
Is this still a ‘should not be happening issue’? If so, I can post the relevant code.
I did some further checking and my program runs, but I get the ***** ASSERT ***** first
If I turn on power to the board, I get:
EMX…version… debug…
Screen Clears
***** ASSERT ***** for several seconds. Then it disappears for a fraction of a second… then it comes back ***** ASSERT *****. This can happen several times (usually about 10-15 seconds worth of this
Then my program runs (it writes to the screen, so I know it is running).
Where should I send the code. I ‘smallified’ the code to simplify the issue as much as possible. All it does is write “Board Test” to the screen. It works fine after about 10 seconds of 4 ***** ASSERT *****.
This seemed to start occurring after I went to firmward version 4.2.7.0
using GHI.Premium.Hardware;
using GHI.Premium.IO;
using GHI.Premium.System;
using System.IO;
using System.Net.Sockets;
//using GHI.Premium.Hardware.EMX;
using System.Net;
namespace EMXbase
public static String strOutputText = "";
public static int iLineCount = 0;
BigText("Board Test");
Thread.Sleep(50);
public static void BigText(String strMessage)
if (strOutputText.Length > 0)
strOutputText += "\n";
iLineCount++;
if (iLineCount > 5)
strOutputText = "";
iLineCount = 0;
strOutputText += strMessage;
Bitmap LCD = new Bitmap(SystemMetrics.ScreenWidth, SystemMetrics.ScreenHeight);
LCD.Clear(); // clears the memory and not the display
//for (int i=10; i<200; i += 4)
// LCD.DrawLine(Colors.Green, 1, 10, i, i, 200); //draw in memory
//Debug.Print("Test");
Font MyFont = Resources.GetFont(Resources.FontResources.small);
//LCD.DrawText(strMessage, MyFont, Colors.Cyan, 20, 20);
LCD.DrawTextInRect(strOutputText, 0, 0, SystemMetrics.ScreenWidth, SystemMetrics.ScreenHeight, 0, Colors.Cyan, MyFont);
LCD.Flush(); // transfer the bitmap memory to the actual display
