I’m making use of the what I think is an undocumented capability of Windows 10 IoT Core - the internal system information Rest API. The only place I’ve found that documents this capability is:
My Rpi C# app uses this API to get system information such as the Ethernet adapter’s MAC address, or dynamically set the audio volume. My Rpi 2 application is using 10.0.10586 and is able make the API calls using localhost without any issues, however the API calls fail via localhost on my Rpi 3 running 10.0.14393.0. I can successfully call the API methods from another machine using the Rpi 3’s IP address or device name, just not from the on-board c# app via localhost.
Any help to get these Rest calls working via localhost is appreciated!
