This has been around for a little while, but I only just remembered to post it.
Nice going on the application. Are you going to add some images? If you have seen the weather application for iphone you will know what I am talking about.
BTW, I can’t wait to see how the custom cases will look like. Should be pretty awesome
Hey Chris,
Nice job buddy! Good skills with the dremel too cutting out the lcd hole. I just got done cutting the panel to access all my ports. Fyi, I found a pocketknife and a little patience was pretty easy if you’re looking to make this.
PS> congrats on going from “junior member” to “senior member”. You definitely earned it!
Hi Matt and Gus,
I actually didn’t use really any power tools to cut the case out, only a few drill holes, a file and an Exacto knife. The first part was just opening the hole up, but we didn’t get lined up quite right, so I had to open it up some more with the Exacto and then later, the file.
