Analogue in question
I have a Panda 3 with SKD 4.3 and VS 2013.
The anologue input pins on the board equate as follows A0 … Analogue_2, A1…Analogue_3 etc. Not a big problem, but unusual they start 2 up.
With the code below I thought I would get close to 4096 for 3.3v and 0 for 0v.
I seem to be getting numbers between zero and one.
Y2 = 0.0004884004884004884 this is the input at ground.
Y2 = 0.99926739926739927 this is the input at 3.3v
Is there a way to configure the port to supply numbers from 0 to 4069?
using GHI.Pins;
namespace Joystick
        #region static variables
        static AnalogInput Y2 = new AnalogInput((Cpu.AnalogChannel)Cpu.AnalogChannel.ANALOG_2);  // A0 on the board
        #endregion //static variables
                Debug.Print("Y2 =  " + Y2.Read().ToString());
                Thread.Sleep(500);
You should use GHI.Pins.FEZPands… to get the right analog channel.
And correct, the returned value is 0 to 1. I can’t remember the method name but I think there was a way to read the raw data but why would you need that? 0 to 1 is easier to deal with and will be the same on any board you are using.
Thanks Gus, that makes sense.
Alastair
