Hello guys,
This might seem a strange question, but if I read “1” on the ADC while reading a analog pin, how much voltage is this representing?
According arduino forums, a arduino has 0.00488V when reading “1” on the analog pin.
So how much is this on the FEZ boards?
And how much voltage can I place on the analog in?
Thanks! ;D
It depends on your scale value. (Arduino doesn’t have built in scaling ;))
So set scale to 3300 and knowing the input voltage is 3.3V, it is 1mv per 1
Thank you, will try it out tomorrow 8)
But then again Arduino has the map function built in that could be used for scaling
(Thats an easy function to implement but I would like to see it as a built in function
Maybe add your map function to fezzer? Should be couple lines of code, right?
As you say, it’s not much code
private uint map(int x, int in_min, int in_max, int out_min, int out_max)
int Puls = (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
return (uint)Puls;
We had a thread on this earlier [url]http://www.tinyclr.com/forum/1/828/[/url]
I’ll add it to Fezzer tomorrow.
Yeah it is small but not everyone knows how to make it. Thanks Geir
