I use the program of analog input . Through debuging the program with the board of FEZ_Panda_II,the result turn out error:a3000000.
The debug window display the sentences:
“Resolving.
Assembly: MFWindowApplication1 (1.0.0.0) needs assembly ‘Microsoft.SPOT.TinyCore’ (4.1.2821.0)
Assembly: MFWindowApplication1 (1.0.0.0) needs assembly ‘GHIElectronics.NETMF.Hardware’ (4.1.7.0)
Error: a3000000
Waiting for debug commands…
程序[14] Micro Framework application: 托管已退出,返回值为 0 (0x0)。”
The code is below.
AnalogIn lightSensor = new AnalogIn((AnalogIn.Pin)FEZ_Pin.AnalogIn.An3);
lightSensor.SetLinearScale(0, 100);
int lightSensorReading = 0;
lightSensorReading = lightSensor.Read();
Debug.Print(lightSensorReading.ToString());
Thread.Sleep(500);
pls help me work out the problem.I am crazy now! ths.
