maybe you “can” work around this by setting a filter on the native can handling?
what’s the exact problem receiving these message back in the native events?
@ Honken - off-topic but since you also are active in can: did you ever get a G120 working with 1Mb CAN speed? Your answer in : http://www.ghielectronics.com/community/forum/topic?id=10910
worked for the lower bit rates but not at 1Mb. I never got this working in test setup but today we tested the first proto pcb’s and it’s not working with a brp 2 (with should be 2.5).
We are looking into poking registers tomorrow, maybe bring G120 the speed back to 100Mhz to get a closer match but I get a strange feeling on this… in the new documentation page from GHI the 1000Kb line is removed for the G120…
I’m not sure if this is a sign on the wall, i asked this question before but never had a strait answer from GHI on that topic. http://www.ghielectronics.com/community/forum/topic?id=11515
If you think you have answers for me please contact me at dv at emrol dot com, cost can be discussed since i’m on realy short deadlines…
