Hi all,
I make a VS Solution for porting Neural Networks to my GHI G400 Dev Board.
If you run MikeLab_DissociativeDisorderer project it will optimize a 2x2 neural network to achieve a AND logic capacity, the project also write that to file in a json format.
This project makes use of backpropagation for learning and BipolarSigmoidFunction for calculations.
Grab the json on the desktop and put on the GHI G400 SD Card.
Launch MikeLab_DissociativeDisorderer_NETMF Project
And you will get it, AND Logic on the G400.
Learning could be changed, change learning data in the first project were there is the comment:
// prepare learning data
Also you could want to change Alpha Sigmoid Value.
You got it, I think that I will try to make a navigation system for a tank robot with this, if the code will be smaller compared to a custom tailored one.
External code and thanks to AForge code and MicroJSON code.
