Is not working for me on Nokia 920. I wonder if other WP8 has same issue?
I confirmed it doesn’t work on mine either. Have you tried through the emulator in VS2012? My PC here won’t run the emulator… I’ll try on my wife’s 820 in a bit but I suspect it’s a WP8 IE problem that effects all WP8 devices.
Same result on Lumia 820.
Unfortunate
No go on HTC 8x…
Guys, I’m not following this. What images are you trying to add to your phone and where/how are you trying to add them?
@ Jason - I was meaning adding a upload to the forum using the phone…i assumed thats what the others where talking about, but maybe…
@ Justin - OK. Understood, let’s see what they come back with too. I thought it might be because they hadn’t been marked as Content and and were not being copied to the device when adding them to a VS2012 phone project.
J.
@ Jason - Your probably right after reading it all again
Uploading images to the posts on this forum from a WP8 doesn’t work. “Browse” button doesn’t do anything.
It does support JavaScript. It is just broken in this particular case on this particular site I suspect.
We just need a native app… Josh, when you giving us the API back?
Can’t do this with a jobsian cult phone either but then im not surpised.
Edit: Isnt a mobile version of the forum on the long term suggestions list??
