This is using a simple DS1672 counter because .NET handles all the time conversion and it’s about the cheapest I’ve found so far with a trickle charge. A 220uF capacitor keeps it running for about 30min and a 1000uF lasts about 2.5hrs. It can hold the time much longer but the counter stops.
One problem I have is that timespan totalseconds isn’t available to me for some reason so I just added it manually.
[url]http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=DS1672-33%2B-ND[/url]
using System.Text;
namespace FEZ_Mini_Application1
static bool ledState = true;
static OutputPort led = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.LED, ledState);
static I2CDevice DS1672RTC = new I2CDevice(new I2CDevice.Configuration(0x68, 400));
Thread.Sleep(1000);
Init();
StartCharger();
Set(new DateTime(2010,10,9,14,36,45));
Timer updateTimer = new Timer(new TimerCallback(Update), null, 500, 1000);
static void Update(object o)
Debug.Print("Time = " + UnixTimestampToDateTime(Read()));
static void Init()
I2CDevice.I2CTransaction[] xActions = new I2CDevice.I2CTransaction[1];
byte[] output = new byte[2];
output[0] = 0x04;//select control register
output[1] = 0x00;//set EOSC to 0 and start oscillator
xActions[0] = I2CDevice.CreateWriteTransaction(output);
DS1672RTC.Execute(xActions, 100);
static void StartCharger()
output[0] = 0x05;//select charger register
output[1] = 0xAB;//set one diode, 4k resistor
static long Read()
I2CDevice.I2CTransaction[] xActions = new I2CDevice.I2CTransaction[2];
byte[] input = new byte[4];
byte[] output = new byte[1];
output[0] = 0x00;//select 1st register
xActions[1] = I2CDevice.CreateReadTransaction(input);
return ((long)input[3] << 24) | ((long)input[2] << 16) |
((long)input[1] << 8) | input[0];
static void Set(DateTime _DateTime)
long seconds = DateTimeToUnixTimestamp(_DateTime);
byte[] output = new byte[5];
output[1] = (byte)(seconds & 0xFF); ;//set register 0 LSB
output[2] = (byte)((seconds >> 8) & 0xFF); ;//set register 1
output[3] = (byte)((seconds >> 16) & 0xFF); ;//set register 2
output[4] = (byte)((seconds >> 24) & 0xFF); ;//set register 3 MSB
static DateTime UnixTimestampToDateTime(long _UnixTimeStamp)
return (new DateTime(1970, 1, 1, 0, 0, 0)).AddSeconds(_UnixTimeStamp);
static long DateTimeToUnixTimestamp(DateTime _DateTime)
TimeSpan _UnixTimeSpan = (_DateTime - new DateTime(1970, 1, 1, 0, 0, 0));
long seconds = (_UnixTimeSpan.Days * 86400) +
(_UnixTimeSpan.Hours * 3600) +
(_UnixTimeSpan.Minutes * 60) +
_UnixTimeSpan.Seconds;
return seconds;
