I’ve got an SMB380 - On the +/-2g my Z-axis seems to rest at -0.5g; the X and Y rest fairly closely to 0. Is there a recalibration procedure I can do on the board?
Your code should calibrate the accelerometer.
If you are indeed getting 0.5g on the Z axis, you may have the accelerometer set to 4g, or your m/s/s per Volts is not correct for the 2g setting.
Can you show us your code.
public sealed class SMB380
public enum GRange : byte
G2 = 0x00,
G4 = 0x01,
G8 = 0x10
public enum FilterBandwidth : short
Hz25 = 0x000,
Hz50 = 0x001,
Hz100 = 0x010,
Hz190 = 0x011,
Hz375 = 0x100,
Hz750 = 0x101,
Hz1500 = 0x110
#region Fields
private SPI spi;
private byte[] read = new byte[2];
private byte[] write = new byte[2];
private GRange _range = GRange.G4;
#endregion Fields
#region Constructor
static SMB380()
Instance = new SMB380();
private SMB380()
spi = new SPI(new SPI.Configuration((Cpu.Pin)FEZ_Pin.Digital.UEXT10, false, 0, 0, true, true, 200, SPI.SPI_module.SPI2));
#endregion Constructor
#region Properties
/// <summary>
/// Gets the current instance of the SMB380
/// </summary>
public static SMB380 Instance { get; private set; }
/// <summary>
/// Gets the Acceleration in the X-direction
/// </summary>
public float AccelerationX
get
short lsb = (sbyte)ReadRegister(0x02);
short msb = (sbyte)ReadRegister(0x03);
return ExtractAcceleration(lsb, msb);
/// <summary>
/// Gets the Acceleration in the Y-direction
/// </summary>
public float AccelerationY
get
short lsb = (sbyte)ReadRegister(0x04);
short msb = (sbyte)ReadRegister(0x05);
/// <summary>
/// Gets the Acceleration in the Z-direction
/// </summary>
public float AccelerationZ
get
short lsb = (sbyte)ReadRegister(0x06);
short msb = (sbyte)ReadRegister(0x07);
public GRange Range
get
return _range;
set
_range = value;
byte val = ReadRegister(0x14);//xxx Range(2) Bandwidth(3)
val &= (byte)(0xE7 | ((byte)value << 3));
WriteRegister(0x14, val);
public FilterBandwidth Bandwidth
get
return (FilterBandwidth)(ReadRegister(0x14) & 0x07);
set
val &= (byte)(0xF8 | (byte)value);
#endregion Properties
#region Private Helpers
private byte ReadRegister(byte address)
write[0] = (byte)(0x80 | address);
write[1] = 0xFF;
spi.WriteRead(write, read);
return read[1];
private void WriteRegister(byte address, byte value)
write[0] = address;
write[1] = value;
private float ExtractAcceleration(short lsb, short msb)
float multiplier = Range == GRange.G8 ? 8.0f : Range == GRange.G4 ? 4.0f : 2.0f;
return (float)(((((short)((msb << 2) | (lsb >> 6))) << 4) >> 4) / 512.0f) * multiplier;
#endregion
Misread the data sheet - it does default to +/-4 - my mistake; however it’s now ~= -1g, which is kind of to be expected I suppose given the earth and whatnot. I take it then that I’d have to report 0 when given that reading?
Also, no matter what I seem to do, I’m always getting 0 out of Register 9, even during an interrupt handler…
private SMB380()
//Enabled latched interrupts
WriteRegister(0x15, (byte)(ReadRegister(0x15) | 0x10));
interruptPort = new InterruptPort((Cpu.Pin)FEZ_Pin.Interrupt.UEXT4, false, Port.ResistorMode.PullDown, Port.InterruptMode.InterruptEdgeHigh);
interruptPort.OnInterrupt += new NativeEventHandler(OnInterrupt);
interruptPort.EnableInterrupt();
private void OnInterrupt(uint data1, uint data2, DateTime time)
//LG
byte register = ReadRegister(0x09);
if ((register & (byte)0x08) > 0)
WriteRegister(0x09, (byte)(register & 0xF7));
Debug.Print("Low-G Threshold");
//HG
if ((register & (byte)0x04) > 0)
WriteRegister(0x09, (byte)(register & 0xFB));
Debug.Print("High-G Threshold");
//Clear the interrupt on the smb380
WriteRegister(0x0A, (byte)(ReadRegister(0x0A) | 0x40));
OK solved the second one- had a phone connected via USB and was getting absolutely nothing out of the SMB380… :
