To answer my previous unknowns…
Here’s a working solution with titlebar, body and statusbar
with runtime updates inside title and status
//Courtesy of Earthed Solutions Pty Ltd (AUSTRALIA)
//www.earthed.net.au
//Custom Embedded and Windows Solutions since 1991
using System.Collections;
using GHIElectronics.NETMF.Glide;
using GHIElectronics.NETMF.Glide.Display;
using GHIElectronics.NETMF.Glide.UI;
namespace FEZ_Cobra_Console_Application_Eg1
public class Titlebar : DisplayObjectContainer
public Titlebar(string name, int width, int height)
Init(name, width, height);
public Titlebar(string name, int width, int height, int iX, int iY)
X = iX;
Y = iY;
public void Init(string name, int width, int height)
Name = name;
Width = width;
Height = height;
Compose();
public override void Render()
// Draw a background first.
Parent.Graphics.DrawRectangle(Rect, Colors.Blue, Alpha);
// Then render the children.
base.Render();
public void Compose()
// Add a TextBlock to display the title.
TextBlock textBlock = new TextBlock(Name + "_textBlock", 255, 0, 0, Width, Height);
textBlock.Text = "I'm the title bar.";
textBlock.FontColor = Colors.White;
textBlock.TextAlign = HorizontalAlignment.Center;
textBlock.TextVerticalAlign = VerticalAlignment.Middle;
// Glue glide objects
this.AddChild(textBlock);
public void SetTitle(string sText)
string sChild = Name + "_textBlock";
DisplayObject Obj = this.GetChildByName(sChild);
if (Obj != null)
TextBlock t = (TextBlock)Obj;
t.Text = sText;
//force redraw of changes
this.Invalidate();
public class Statusbar : DisplayObjectContainer
private string msUser;
public Statusbar(string name, int width, int height)
public Statusbar(string name, int width, int height, int iX, int iY)
X = iX;
Y = iY;
Name = name;
Width = width;
Height = height;
msUser = "";
Compose();
public void SetUser(string sUser)
msUser = sUser;
public string GetUser()
string sRet = "User: ";
if (msUser.Equals(""))
sRet = sRet + "---";
sRet = sRet + msUser;
return sRet;
public string GetTime()
string sRet = "";
DateTime t = DateTime.Now;
sRet = t.ToString("H:mm:ss");
return sRet;
// Add a TextBlock to display user & Time.
TextBlock statusBlock = new TextBlock(Name + "_statusBlock", 255, 0, 0, Width, Height);
statusBlock.Text = GetUser() + " " + GetTime();
statusBlock.FontColor = Colors.White;
statusBlock.TextAlign = HorizontalAlignment.Right;
statusBlock.TextVerticalAlign = VerticalAlignment.Middle;
this.AddChild(statusBlock);
base.Render();
public void SetStatus()
string sChild = Name + "_statusBlock";
if (Obj != null)
t.Text = GetUser() + " " + GetTime();
this.Invalidate();
public class Body : DisplayObjectContainer
public Body(string name, int width, int height)
public Body(string name, int width, int height, int iX, int iY)
X = iX;
Y = iY;
Name = name;
Width = width;
Height = height;
Parent.Graphics.DrawRectangle(Rect, Colors.White, Alpha);
base.Render();
// This will hold the windows.
static Window[] windows = new Window[3];
static Titlebar mTitlebar;
static Statusbar mStatusbar;
static Body mBody;
// Indicates the current window index.
static int index = 0;
public static void Calibrate()
//Essential to make touch match graphics
Glide.FitToScreen = true;
//Activate touch, to ensure touch points matches graphics objects
//essential after upgrade Fez Cobra from 4.1.3 to 4.1.6 and screen defaulted back to 320x240
GlideTouch.Initialize();
const int CAL_POINTS = 5;
short[] sx = new short[CAL_POINTS] { 240, 48, 48, 432, 432 };
short[] sy = new short[CAL_POINTS] { 136, 26, 246, 246, 26 };
short[] cx = new short[CAL_POINTS] { 478, 189, 169, 781, 790 };
short[] cy = new short[CAL_POINTS] { 481, 238, 741, 767, 231 };
Microsoft.SPOT.Touch.Touch.ActiveTouchPanel.SetCalibration(CAL_POINTS, sx, sy, cx, cy);
int Title_H = 30;
int Status_H = 30;
int Body_H = Glide.LCD.Height - Title_H - Status_H;
// Setup LCD and TouchScreen
Calibrate();
// Title bar
mTitlebar = new Titlebar("titlebar", Glide.LCD.Width, Title_H, 0, 0);
// Status bar
mStatusbar = new Statusbar("statusbar", Glide.LCD.Width, Status_H, 0, 0 + Title_H + Body_H);
// Body Content (varies every time)
mBody = new Body("body", Glide.LCD.Width, Glide.LCD.Height - mTitlebar.Height - mStatusbar.Height, 0,0 + Title_H);
// Add a TextBlock to body (button etc)
TextBlock bodyBlock = new TextBlock("bodyBlock", 255, 0, 0, Glide.LCD.Width, 60);
bodyBlock.Text = "Earthed Solutions Pty Ltd";
bodyBlock.FontColor = Colors.DarkGray;
bodyBlock.TextAlign = HorizontalAlignment.Center;
bodyBlock.TextVerticalAlign = VerticalAlignment.Middle;
int iBtn_H = 50;
int iBtn_W = 150;
Button bodyButton = new Button("bodyButton", 255, ((Glide.LCD.Width -iBtn_W)/ 2) , ((Glide.LCD.Height -iBtn_H)/ 2) , iBtn_W, iBtn_H);
bodyButton.Text = "OK";
mBody.AddChild(bodyBlock);
mBody.AddChild(bodyButton);
// Create window
Window W = new Window("Window", Glide.LCD.Width, Glide.LCD.Height);
W.BackColor = Colors.White;
// Glue Together
W.AddChild(mTitlebar); //Top
W.AddChild(mBody); //Middle
W.AddChild(mStatusbar); //Bottom
// Assigning a window to MainWindow flushes it to the screen.
Glide.MainWindow = W;
int i = 0;
bool bUser = false;
//Update Time and user info on Screen
mStatusbar.SetStatus();
Thread.Sleep(10);
i++;
//Arbitrary Update of Title
mTitlebar.SetTitle("www.earthed.net.au" + " [" + i.ToString() + "]");
if (i > 50)
i = 0;
bUser = !bUser;
if (bUser)
mStatusbar.SetUser("Earthed.Ian");
mStatusbar.SetUser("GHI.Josh");
If anyone has any enhancements on this please feel free to mention on this thread
Youtube Video of the above code attached:
